Stroud nylon trany blanket enough? - Chevelle Tech
post #1 of 2 (permalink) Old Jan 18th, 10, 12:17 PM Thread Starter
Need a trans shield, and also I guess a flexplate shield. The picture of the Stroud #516 looks good, can't slip because it is bolted to the bellhousing, and I won't have to remove the trans I believe. At $165 bucks, it is cheap enough. The Kevlar blanket on the other hand well, it is expensive. This is going on a 10.90 '75 Camaro with a turbo 400. Any thoughts??
"We try to at all times at least assume that the world is not being properly run." Paul Singer (Elliot Management)
ejrempel is offline
post #2 of 2 (permalink) Old Jan 18th, 10, 5:08 PM
Vince
Re: Stroud nylon trany blanket enough?
http://www.jegs.com/i/CSR/170/832/10002/-1
these are 1-piece and cover both the bell and length of the tranny.
VinceS427bb is offline
