12 bolt rear end codes? - Chevelle Tech
post #1 of 4 (permalink) Old Mar 22nd, 09, 3:58 PM Thread Starter
john
I have a 12 bolt rearend that im rebuilding and converting to a possi. I have sand blasted it removed all the bearings and gears. The codes on the rearend are CKD 0826B, GM52, 3969278NF, H48, CON1, E stamp under cover, 1234567890. I have surched the Internet and the 3969278NF is supposed to be a 71-72 but date code dosent match. Please help make sense of this because im confused.
ripper1711 is offline
post #2 of 4 (permalink) Old Mar 22nd, 09, 4:08 PM
& Administrator
Re: 12 bolt rear end codes?
Appears to be from a '70 per the info I've got.
The 3969278NF was used '70-'72.
Your code CKD was '70.
Possible that the 8 in the H48 is a 0 ??
Mike is offline
post #3 of 4 (permalink) Old Mar 22nd, 09, 4:21 PM
Terry
That casting nimber was used from 70-72 but chevellestuff.com shows that your rear is a 1970, because that is the only year that shows a CKD code. Meaning it was a 2:73 ratio.
08 means the 8th month, 26 is the date and B means it was built at the buffalo plant
Terry
ACES # 5021
Experience is something you don't get until just after you need it.
bcice is offline
post #4 of 4 (permalink) Old Mar 22nd, 09, 4:57 PM Thread Starter
john
i think its a 9 the 8 9 look close alike but not a 0 diffently
