electronic trans 4l60/4l80e behind a carb motor? - Chevelle Tech
post #1 of 11 (permalink) Old Nov 12th, 08, 6:51 PM Thread Starter
Aaron
is it possible to run a 4l60e or 4l80e trans behind a carb non computer controlled motor?
i want to put an OD trans in the chevelle i would love to put a tremec tko in, but then i would have to spend 2000 on a 12 bolt. i would like to keep what i have.
i am also wanting to make it my dd again, and with the 355's it doesnt work out to great, as 80% of my driving is highway.
i can get a 4l60e for dirt cheap, and a 4l80e if i look in the yards. are they possible to run without a computer control motor?
thanks
aaron
1971 Chevelle. 355, megasquirt efi. On3 7875 turbo. 4l80e, py3600, 355 gears. C5 brakes, SC&C stg2+, hellwig bars, 04-06 gto seats. 546rwhp/450rwtq with 28% converter slip on 18psi!
Little walk around video
http://youtu.be/D_B0B1RNmcc
BowtieAaron is offline
post #2 of 11 (permalink) Old Nov 12th, 08, 8:10 PM
Re: electronic trans 4l60/4l80e behind a carb motor?
I believe there is a stand alone computer available to run the transmission.
I never make mistakes, but on occasion I present myself with an opportunity to get very creative.
animal69 is offline
post #3 of 11 (permalink) Old Nov 12th, 08, 8:21 PM
& Administrator
Mike is offline
post #4 of 11 (permalink) Old Nov 12th, 08, 11:44 PM Thread Starter
Aaron
thanks guys.
main reason i want to run an electronic trans s so i can use a lock up converter, or am i able to run a lock up converter in a non electric trans like an old 700r4
aaron
post #5 of 11 (permalink) Old Nov 13th, 08, 1:31 AM
You'd be MUCH better off to use a non-computer-controlled transmission.
You can lock the converter with a manual switch (not recommended) or with a few junkyard parts; some primary wire, and perhaps a brake switch for a car with cruise control. With luck, you'll get all the parts from one donor vehicle.
I bought a TCI kit for locking the converter. It's been awhile, but I'm pretty sure it was this one:
http://store.summitracing.com/partde...5&autoview=sku
It was simple and it worked...mostly. The vacuum switch was adjustable, just as claimed. Problem is, it had no hysteresis. The converter was always locking and unlocking at cruise, and it made me crazy. At cruise, the engine builds some RPM and some vacuum--the vacuum switch closes; the converter locks. The RPM drops, and the vacuum drops, too--and the converter unlocks. But that allows a bit more RPM and vacuum, so the converter locks again...
Insane.
A proper vacuum switch would close at a higher vacuum level than it opens. TCI should have known better than to provide a crappy vacuum switch.
When I do this again--I have Cliff Ruggle's new book, and a core 700 R4 transmission selected--I'm using a GM vacuum switch. Route power through the brake switch, the vacuum switch, and then to the trans.
Schurkey is offline
post #6 of 11 (permalink) Old Nov 13th, 08, 3:42 AM
Robin
I have a 4L80e in my 70 chevelle. I love the OD and lock-up.
The engine is a 350 with edelbrock intake and carb. (still working on the 396)
I use a set from compushift to control the 4L80e.
It is easy to install and works great. I used there AccuLink Throttle Position Sensor behind the edelbrock carb. You can program almost everything with the display.
I bought it from www.bowtieoverdrives.com but there are more brands (like TCI) that make a stand alone set/kit to control a 4L80e.
1970 Chevelle SS, 396, 4L80e, 12 bolt 3.55
http://www.chevelles.com/showroom/da...dium/side4.jpg
70-SS-396 is offline
post #7 of 11 (permalink) Old Nov 13th, 08, 9:22 AM
you can use a stand alone computer to program it-i actually have a GM one, brand new, same as the older tc1 unit, for 4l60e or 80e, gonna list it on ebay for $600
im going to use man shift on the 4l80e
when your credit cards are maxed, have the limits raised
forcd ind is offline
post #8 of 11 (permalink) Old Nov 13th, 08, 2:58 PM
steve
70-SS-396 (Robin)
Does it fit in the tranny tunnel well? No mods? Where did you mount the tranny control module? What type of gas mileage did you notice as an increase with the OD tranny? Does it drop in/out of OD in crusing speed? Did you pick the correct rear gear? can you cruise at 70-75 mph all day long with the 454?
pestwagon is offline
post #9 of 11 (permalink) Old Nov 13th, 08, 5:01 PM Thread Starter
Aaron
i have a 4l60e in my trans am. it takes a licking and keeps on giving. works great.
i have no issues with kicking out of OD until i push it down more than 3/4 throttle. just a quick blurp it pulls out of lock up.
at 115 im at 3500 in lock up in the bird with 323 rear gears. at 3000 in the velle in 4th with 355s im going about 55.
this is the reason i was asking about the 4l60/80e since i own one, i like it.
aaron
post #10 of 11 (permalink) Old Nov 13th, 08, 6:37 PM
Robin
Originally Posted by pestwagon View Post
70-SS-396 (Robin)
gas mileage? it's a 70 chevelle with full interior
350 (cam unknown, very small) edelbrock performer intake and 600cfm carb. Th350, 3.73 and eaton posi. 235/60-15 tires
Mixed town and highway driving with (octane 95) normal fuel around here. I got 15MPG. The car does have the same 350 (I’m still busy getting the 396 together) but with a 4L80e and 3.55 with eaton posi. 235/60-15 tires again with mixed town and highway driving on octane 95. I get almost 19MPG.
Because of the fuel prices ($6.50 a gallon now, but $9.00 a gallon a month ago) I love my O/D trans.
It turned 3000rpm at 60mph first, but now 2500 with 72mph. I like that. (speed limit is 75mph on the high way in this country) when I drive it 3 hours I am across the whole country , so all day? I don't no, sorry.
Top speed is 119mph. (That is why I love the German high way, they don't have a speed limit on it) and still with the old 350 engine with stock exhaust. (this engine turns only 4500rpm max, it does not mather in wich gear)
Some people say you don't need to mod the tunnel, but I needed to make two small dents. one at the underside of the fire-wall, in the middle just where the tunnel starts and one at the end of the tranny. I used the th350 crossmember, turned it around and re-welded the tranny-mount into the middle of the tube. I only needed to drill two new holes for the crossmember. And ofcourse the drive shaft is a bit shorter now (about 1.5 inch)
The module is under the passengers seat and I made a bracket to hold the controller. The bracket fits into the two holes in the metal part inside the ashtray, the controller now fits perfect into the hole of the ashtray when it is open. When I park the car I can take the controller out and everything looks stock.
It goes into 4th gear even at 30mph, but that is because of my Compushift settings. You can program it to lock-up at any speed in 4th gear or 3rd and 4th or not at all. the lock-up goes of at a % of increase or decrease in speed or throttle. You can also shift manual with switches. Do a search on google.com for compushift, I no there is a lot of info about it but I can't find the links in my computer.
The only problem I have is the 1st to 2nd gear shift. When I have more then 1/2 throttle the rear tires squeak for a second when it upshifts. I still can't find out what the problem is.
Hope I helped a bit. Sorry for the long answer.
post #11 of 11 (permalink) Old Nov 13th, 08, 9:33 PM
steve
wow, a 20% increase in mileage and comfortable cruising rpms...NICE!!!
