both 10 bolts, different u-joints. - Chevelle Tech
post #1 of 2 (permalink) Old Mar 25th, 08, 9:40 AM Thread Starter
Cody
K so i finally found a 10 bolt posi rear end for a decent price, i had to get the spring perches moved back some but everything else bolted up fine.. but the yoke is a newer style with the clips on the inside and the u-joints i have are just a little to small.. can you but a u-join with liek the stock size on one end and a little bigger on the other?
69 Chevelle
72 350 .030 over, 2.02 Heads, Victor Jr. Intake, .525/.546 VooDoo Cam, Forged Scat Crank, Forged Rods & Flat Top 10.5:1 Pistons, Holley 780 Double Pumper, Flowmaster 40's,Built TH350 w/ 2800 stall, 4.10 gears.
xCornell07 is offline
post #2 of 2 (permalink) Old Mar 25th, 08, 12:02 PM
Send a message via MSN to Whiskey
Re: both 10 bolts, different u-joints.
Yes you can. I think they call them conversion u-joints. Call any driveline shop and they should be able to hook you up.
68 Chevelle
427 w/Merlin heads
10.2 to 1 comp
Hooker headers
Art Carr 200R4 w/3500 stall
3:90 Posi
72 SS 454
Hooker Headers
400 turbo
3:31 gears
Whiskey is offline
This Thread is more than 3349 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
