10 bolt yoke saddles - Chevelle Tech
post #1 of 3 (permalink) Old Mar 17th, 08, 10:42 AM Thread Starter
does anybody sell these? I tried to use the saddles on my 12 bolt which are different. It looks like this uses a u bolt to hold the u joint in.
fabio is offline
post #2 of 3 (permalink) Old Mar 17th, 08, 11:52 AM
Re: 10 bolt yoke saddles
Check with your local napa or car quest they should have the u bolts in stock, they are usually on the "HELP" rack.
69 elCamino 454 10.5 compression
Comp hyd roller 232@050 578 lift 106 lc
Edelbrock aluminum heads, 2.25 & 1.89 valves, BG 850 double pumper, Air gap intake, Jeep steering box, hydroboost, 4 wheel disc brakes
M21 4 speed, 12 bolt, Yukon Duragrip posi, 3.73 gears
http://i194.photobucket.com/albums/z...g?t=1277519962
AXEMAN39 is offline
post #3 of 3 (permalink) Old Mar 17th, 08, 12:37 PM Thread Starter
yeah thanks, they are the only local auto parts that even carried it.
fabio is offline
This Thread is more than 3328 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
