OK....transmission cooler line help!! - Chevelle Tech
post #1 of 6 (permalink) Old Mar 16th, 08, 11:42 AM Thread Starter
Paul
Ok.... like i said, i need some help with my TH350 transmission cooler lines. Is the top one on the trans the return and the lower one the pressure??
I know this has been talked about many times before, and when i do a search i find a bunch of great info. But when i look at my transmission cooler instructions from B&M and they are different from my Chevelle service manual and then my dad and i argue which line is which i cant tell what is what any more!!!
I looked at TCIAUTO.COM and they say upper is return and lower is pressure. But then i know i have heard different and i think my B&M super cooler instructions say the opposite and i cant remember right now what my service manual says! But is TCI right?? I think they are but im not positive!! Thanks for all the help guys!!
Also, when i put the cooler lines on, the pressure from the trans (hot) goes in the top of the radiator then flows down and out the bottom right??
Thanks again!!!
~Paul
1971 Chevelle Silver and Black. SB 409 TH350 and 12 bolt with posi and 3.73s.
'71SB409 is offline
post #2 of 6 (permalink) Old Mar 16th, 08, 4:54 PM
Re: OK....transmission cooler line help!!
Pull a tube out of the radiator, aim it at a big bucket. Put a temporary tube into the radiator with the open end also aimed at the bucket. Start the engine, see which tube shoots fluid, and you'll have your answers first hand with no possibility of mistake.
Schurkey is offline
post #3 of 6 (permalink) Old Mar 16th, 08, 5:26 PM
Mark
Not sure on the TH350, but on the TH400 I believe the upper tranny outlet is the return line.
Mark
1970 SS396
Lewis Racing Engines (Wolfplace) 489:
634 HP @ 6000rpm
627 Lb-ft @ 4,000rpm
ProSystems SV1
Gear Vendors Overdrive
Moser 12 Bolt
Alumitech Radiator
Pypes Exhaust
Dyno
'70 Chevelle
'70 Chevelle 2
Xtreme70SS396 is offline
post #4 of 6 (permalink) Old Mar 16th, 08, 6:01 PM
Papa
Thanks again!!!
~Paul
This will help!
http://tciauto.com/Products/TechInfo...r_fittings.asp
Mr Chevelle is offline
post #5 of 6 (permalink) Old Mar 17th, 08, 1:15 PM Thread Starter
Paul
Well...Thanks guys!!! I have already read TCIAUTO.COMs thing and i took note of that. The thing is, i wanted to make complete sure its right. Schurkey, i would try that but i dont have anything hooked up at all! I made new tranny cooler lines and put in a new radiator, so i wanted to hook them all up once and not go through it again! I might just have to put them on and move them around later, its just such a pain that i wanted to just do it once!! Thanks for the help guys!!!
~Paul
'71SB409 is offline
post #6 of 6 (permalink) Old Mar 19th, 08, 5:52 PM Thread Starter
Paul
OK!! I talked to Hughes, B&M, and checked the TCI web page as i stated, and they all ended up giving me the same thing!
-The bottom fitting on the tranny is the out (pressure, hot fluid to the radiator or whatever you wanna call it)!
-The top fitting on the tranny is the in (return, cooler fluid or from the radiator whatever you wanna call it)!
Thanks for all the help and ideas guys, believe me, if i didnt have my headers off and at the shop getting coated and i wasnt still working on my radiator, i would have just taken hoses off and ran it quick to see which was which. But i guess if 3 places all say the same thing thats what im going to go with!! Thanks for all of the help and suggestions guys!!
~Paul
'71SB409 is offline
This Thread is more than 3324 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
