12 bolt differential question - Chevelle Tech
post #1 of 8 (permalink) Old Mar 2nd, 08, 3:10 PM Thread Starter
Exclamation 12 bolt differential question
I found a 12 bolt out of a 1972 Monte Carlo and am going to put it in my 1969 chevelle, The question I have is this, it has 2.73 gears in it and I want to go to 4.56 Richmond Pro gears, I want to run a full spool also, will the spool and gears fit in this differential with out a spacer? Thanks for any help. Bill.
napa219 is offline
post #2 of 8 (permalink) Old Mar 2nd, 08, 3:29 PM
Marcus
Re: 12 bolt differential question
Yes it will fit.
Marcus
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
12 bolt Eaton posi Us gear 3.31 Toms KA 33 splines axles
Malibu ss 64 is offline
post #3 of 8 (permalink) Old Mar 2nd, 08, 3:47 PM Thread Starter
Thanks Marcus. Bill napa219
napa219 is offline
post #4 of 8 (permalink) Old Mar 2nd, 08, 3:51 PM
Papa
Can you run a full spool without "C" clip eliminators?
Mr Chevelle is offline
post #5 of 8 (permalink) Old Mar 2nd, 08, 3:54 PM
Marcus
You meant a full spool right? Not a minispool?
Marcus
post #6 of 8 (permalink) Old Mar 2nd, 08, 3:59 PM
Marcus
No I think you canīt.
Marcus
post #7 of 8 (permalink) Old Mar 2nd, 08, 4:02 PM
Papa
That's what I thought.
post #8 of 8 (permalink) Old Mar 2nd, 08, 8:10 PM Thread Starter
I am going to use c-clip eliminators and moser axles. A mini spool would work with c clip axles. Thanks. Bill napa219
napa219 is offline
