auburn posi - Chevelle Tech
post #1 of 2 (permalink) Old Feb 8th, 08, 12:45 PM Thread Starter
Cool auburn posi
I hate being a pain in the rear end.Will a auburn posi #5420113 bop 8.2 10 bolt 28 spline work in a 66 chevelle 10 bolt.It says it fit buick pontaic olds n years 64 to 71.
speedy 0305 is offline
post #2 of 2 (permalink) Old Feb 8th, 08, 2:39 PM
Re: auburn posi
I believe if I read right it is a non c-clip unit for an 8.2 with 28 spline axles and a 27 spline pinion and will not work with a c-clip with 25 spline pinion shaft.
PaPa Johns 77 is offline
This Thread is more than 3393 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
