Trans Question - Chevelle Tech
post #1 of 2 (permalink) Old Feb 5th, 08, 6:46 PM Thread Starter
Chuck
Send a message via Skype™ to chas59
Trans Question
I am restoring a 1968 ss. I am trying to decide which transmission to use. I have a saginaw 4 speed that was rebuilt. Have been told that it would scatter behind my 396, which is built basicly just over stock. I do not want to put it in if that will happen. Can anyone help me with this. Will that happen, or am I worrying for nothing? Also, can anyone tell me what this trans is out of?
Tranny numbers are as follows.
Main Case GM 2 3825658
Side Cover GM 3920798 L 16 7
Tail Shaft 20 GM 3860042 b 22 8
chas59 is offline
post #2 of 2 (permalink) Old Feb 5th, 08, 7:39 PM
Re: Trans Question
Here's what I found out when building my 69 with 454. Street build, no racing, just some feel good experiences every now and then.
I too had a car with a Saginaw. The Saginaw was built by GM for 6 cylinder an small V-8 cars. Needless to say, not advised for a big block, and resale value with a Muncie makes it correct.
Find a good Muncie 4-speed 10 spline input 27 spline output and use that.
If I had to do it all over again I'd gow with a newly rebuilt Muncie rather than finding one, getting it built, etc. M-20 for 3:31 gear and down, M-21 for 3:55 up.
Several guys on here can recommend where to buy one completely rebuilt.
Good luck.
larietrope is offline
This Thread is more than 3368 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
