Transmission books - Chevelle Tech
post #1 of 5 (permalink) Old Jan 12th, 08, 2:13 PM Thread Starter
Paul
Smile Transmission books
So for a senior project I am going to rebuild and modify a th350 transmission, I would like to get a couple books on the matter. What do you guys recommend? I know of the Ron Sessions book, but does this cover modification of a transmission for double feeding the clutches and stuff. I've also been dealing with Jake's Performance, and his comes with step by step instructions.
This kind of intimidates me because I've had lots of bad experiences with transmissions. Any help is greatly appreciated.
Here's the book I was looking at http://store.summitracing.com/partde...5&autoview=sku
Trying to break the 13's $1 at a time
1965 El camino
http://s88.photobucket.com/albums/k1...20El%20camino/
65lkey is offline
post #2 of 5 (permalink) Old Jan 12th, 08, 2:19 PM
Re: Transmission books
i used that book to do my first rebuild-the biggest thing to do is find someone to r & r the bushings
when your credit cards are maxed, have the limits raised
forcd ind is offline
post #3 of 5 (permalink) Old Jan 12th, 08, 3:57 PM
Ray
Check out this site,
http://www.atsg.biz/
Click on "Bookstore"
Everything you wanted know about trannys but were afraid to ask..LOL
Hope this helps
Ray
rhm1956 is offline
post #4 of 5 (permalink) Old Jan 12th, 08, 8:06 PM
George
I would recommend the CD. It doesn't go into modifying the transmission but it does show step by step how to take it apart and put it back together. The Ron Sessions book is very helpful also. I just built my first transmission today. I hope to put it in next weekend.
y72ss is offline
post #5 of 5 (permalink) Old Jan 12th, 08, 10:07 PM
http://www.ckperformance.com/resourc...CALMANUAL.html
www.ckperformance.com christoforos kokkonis gm transmission specialist.engineering and design of the finest street,strip,drag race automatics,custom ratio planetary gears ,unbreakable shafts,drums,hubs,pro tree brakes,valve body kits etc.
christoforos kokkonis is offline
