How much power will a 1330 joint handle - Chevelle Tech
post #1 of 10 (permalink) Old Apr 23rd, 07, 12:44 PM Thread Starter
Just wondering how much power a 1330 u joint will handle when at the trans slip yoke? When I bought my tko I was told that the slip yoke could hold either a 1330 or 1350--was made for 1330's. I am having a new driveshaft made and the guy said he could build it so I have a 1350 in the rear, which I have a pinion yoke for a 1350, and then put the 1330 up front. Does this make since or should I just buy an over priced trans yoke that will hold a 1350? This is an all street car with no slicks, but does have a 574hp 385. My question is will the 1330 trans yoke and parts handle this much power behind a straight gear trans. I have to make a decision in the next day or so.
tumper93 is offline
post #2 of 10 (permalink) Old Apr 23rd, 07, 12:50 PM
Re: How much power will a 1330 joint handle
A 1330 will be fine if that's what you have. I ran 1310's front and back on my car with the grease fittings. This was with 625 hp and a trans brake going 10.30's .
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.034 at 148.10, 1.242 60'
bracketchev1221 is offline
post #3 of 10 (permalink) Old Apr 23rd, 07, 3:52 PM
Harold
By the Spicer book, a 1310 u joint is rated for130 lb.ft. torque;800 short duration.1330 @150;890 short; 1350 @210; 1240 short . I would recommend upgrading now and eliminate the weak link
driveshaft-texas is offline
post #4 of 10 (permalink) Old Apr 23rd, 07, 4:50 PM Thread Starter
Is there a way to have a 1350 joint in the front with the caps to fit the 1330 slip yoke? If that is possible then I can have it made for 1350's front and rear and upgrade the slip yoke at a later time.
tumper93 is offline
post #5 of 10 (permalink) Old Apr 23rd, 07, 5:19 PM
They do make hybrid joints but you need a good parts person to go through the book I'm not positive on your application though if you get stuck I have a good parts person to go to or BGH should know.
Mike Lewis street 572
http://www.lewisracingengines.com/
Holley HP EFI
Marcella Manifolds
Heads by Darin Morgan
Wires from Rick@Firecore
www.firecore50.com/
Cam by UDHarold
.456 X 1.8/1.7
Menscer Motorsports
http://menscerms.com/
R2C Filters
www.r2cperformance.com
Ultra Carbon
www.ultra-carbon.com/
GF-5R,
http://trzmotorsports.com/wp2/
TRZ FAB 9" 4.56 REM, Cryo Treated
4000 lb street car
My Showroom
aukai is offline
post #6 of 10 (permalink) Old Apr 23rd, 07, 9:57 PM
You will be fine. I ran a 1310 in a 4000# 4spd car that ran 10.90s with no problems but you must keep an eye on them.
Mike Feudo is offline
post #7 of 10 (permalink) Old Apr 24th, 07, 9:36 AM Thread Starter
I guess that is what I will do then. Just to make sure you understood, I have a 1350 at the pinion yoke and the slip yoke at the trans is the only 1330. So I should be okay like this is what ya'll are saying?
tumper93 is offline
post #8 of 10 (permalink) Old Apr 24th, 07, 11:49 AM
Ray
If you wanna' go that route, Neapco part number 2-3050 is a 1330/1350 conversion u-joint.
'70 Elky SS
Daily Driver
ZZ502, TH400, 3.07 posi
Horrible mileage - great smileage!
The Elky & friends
The 502
70ElkySS is offline
post #9 of 10 (permalink) Old Apr 25th, 07, 12:36 PM Thread Starter
Well, just to let everyone know, I decided to be safe than regret my decision. I went ahead and ordered the driveshaft with 1350's front and rear and I will just get another slip yoke for a 1350 joint. I am not sure who makes my slip yoke and with all the foreign stuff around anymore I didn't know if it was US made or not. Like I said better safe than sorry, you know what the driveshaft will tear up if it comes apart at speed!!!!!
tumper93 is offline
post #10 of 10 (permalink) Old Apr 26th, 07, 10:58 AM
1310 series spicer 1,620 foot pounds
1330 series spicer 1,840 foot pounds
1350 series spicer 2,210 foot pounds
My new used car has 1350 driveshaft and front tranny yoke with a 1310 rear pinion yoke. Go figure.
Anyway it was a 10.50 car and I am not aware of any U Joint problems.
But I am changing the rear pinion yoke to 1350.
Cheap insurance.
1966 Beaumont SD
hydraulic roller 468 12.22 at 109
1970 Nova
solid roller 461 11.49 at 119
Sandy is offline
The L-78 1966 and 1967 Power Options: SAUSAGE Restoration Corner 7 Jul 22nd, 06 11:02 AM
400 yoke for 1330 joint forcd ind Transmission & Driveline 4 Oct 29th, 05 9:33 AM
Power Supply issues, WTB 3 ATX power supplies no1dc Bug Hunt 7 Aug 26th, 05 11:29 AM
Power Seats oman Interiors 5 Jun 5th, 05 11:38 PM
What sort of power will a Powerglide and 10 bolt handle? Byfield 1999 -- 17 Oct 14th, 99 4:43 AM
