3 or 4 series Carrier for 12 Bolt,,,How to tell the diff. - Chevelle Tech
post #1 of 2 (permalink) Old Sep 20th, 06, 10:31 PM Thread Starter
How can you tell the difference between a 3 and 4 series carrier visually. Any numbers or measurements....Also whats the diff between the car and truck 12 bolt....Thanks for the help....
12 Bolt Posi Carrier
glamis44 is offline
post #2 of 2 (permalink) Old Sep 21st, 06, 7:49 PM
Freddie
Re: 3 or 4 series Carrier for 12 Bolt,,,How to tell the diff.
There is a casting number on the end of the Eaton posi. The 3 series is a EDB30140 and the 4 series is a EDB30174. The number is next to the bearing on the end opposite of the ring gear. The truck posi is weaker and has a different offset on the ring gear flange.
big gear head is offline
Posi Carrier Series ????? htm Transmission & Driveline 19 Feb 3rd, 07 9:06 PM
3 series open carrier greebs99 Transmission & Driveline 7 Sep 1st, 06 8:53 AM
Gear Ratio Question 3.91's for a 4 series carrier? Ron454 Performance 21 May 30th, 06 5:21 PM
Strange Gear: 3.73:1 2 Series Carrier 8.2? BGH? Slowpoke70 Transmission & Driveline 18 Jul 9th, 05 11:24 PM
Richmond 3.73 gearset for 4 series carrier Tino Transmission & Driveline 1 May 2nd, 05 5:30 PM
