Strength of a BW Super T-10 - Chevelle Tech
post #1 of 28 (permalink) Old Sep 14th, 06, 12:18 AM Thread Starter
Mic
I have a 2.64 first gear ST-10 in my Malibu.
They trans is basically brand new - 6000 original miles.
How much torque can these things handle?
I will be drag racing about once a month - NO SLICKS.
64CDNSS is offline
post #2 of 28 (permalink) Old Sep 14th, 06, 12:49 AM
Kyle
Send a message via Yahoo to justkyle
Re: Strength of a BW Super T-10
They are pretty tough. As long as you don't really slam the gears. I blew the second gear slider out of my buddies '66/396 last year. It broke the collar off the slider. Im glad he has a sense of humor and I did it in front of his house.
Kyle
70 malibu race car
How to build a proper TFH
justkyle is offline
post #3 of 28 (permalink) Old Sep 14th, 06, 5:33 AM
Wally
Guest
Posts: n/a
The Richmond web site has the torque ratings and they are fairly low.
Part No. Description 1st 2nd 3rd 4th Rev. Torque
1304000070 2.43 “S” Ratio 2.43 1.61 1.23 1.00 2.35 375 Ft. Lbs.
1304000069 2.64 “W” Ratio 2.64 1.75 1.34 1.00 2.55 325 Ft. Lbs.
7021090 2.64 “X” Ratio 2.64 1.60 1.23 1.00 2.55 325 Ft. Lbs.
1304000072 2.88 “CC” Ratio 2.88 1.91 1.33 1.00 2.78 300 Ft. Lbs.
1304000062 2.88 “Y” Ratio 2.88 1.74 1.33 1.00 2.78 300 Ft. Lbs.
1304000071 3.42 “Z” Ratio 3.42 2.28 1.46 1.00 3.51 286 Ft. Lbs.
General Specifications
post #4 of 28 (permalink) Old Sep 14th, 06, 6:18 AM
Wally, I thought that the st10 was supposed to be equal to or stronger than an M22? Are the muncies rated for less?
TC#3095
dreis454 is offline
post #5 of 28 (permalink) Old Sep 14th, 06, 8:38 AM
Keith
For what it's worth, we have a 2.64-1 aluminum Super T-10 behind the 360 hp 455 in our Lemans Sport. This engine is factory rated at 500 ft/lb of torque. Probably a little high. This car is considerably quicker than our L78 Chevelle, making some decent power. The transmission has stood up to 10K miles of street tire abuse. Slicks will find the weak spots pretty quickly, if they are there. The steel mid plate and cast iron case add strength as well but not all T-10s have them. I've heard about GM going to the iron case due to warranty problems. The aluminum transmission would have to be pretty weak if the late '80s cars could hurt it. They weren't making much power back then. Perhaps I have been just lucky.
Keith Tedford is offline
post #6 of 28 (permalink) Old Sep 14th, 06, 9:54 AM
Wally
Guest
Posts: n/a
I'm glad Richmond post real life torque ratings. I think they are playing it safe. As for the Muncie, GM did not play the HP and torque game that other vendors seem to like.
They put Muncies in some real torque monsters, the 455 SD Pontiac, 455 Olds motors, 454 Chevelles and some nasty vette combos and thy seem to live
post #7 of 28 (permalink) Old Sep 14th, 06, 2:11 PM
Jason
Send a message via Yahoo to 136679ss
Alright then what's a real world value of a 1304065903, unknown if it has nickel gears or the like but assuming it doesn't what's it worth? More than same as or less than a muncie?
TC#2693
Aces# 7467
Heart of Dixie CC
136679ss is offline
post #8 of 28 (permalink) Old Sep 14th, 06, 2:27 PM
Wally
Guest
Posts: n/a
Good question. That is the aluminum version and all the info on the site is the iron case stuff.
It is weaker the the 904 trans.
post #9 of 28 (permalink) Old Sep 14th, 06, 3:28 PM
Maybe I'm misunderstanding what you're saying, but Richmond never made an St-10 with the Iron case/midplate. Those torque figures you posted above are all for the aluminum case/midplate trans with standard gears(non nickel). Borg Warner made very few of the 904 case trans compared to the aluminum case version, I have yet to see any torque figures posted on the iron case trans.
I'm running a 2.43 first 904 iron case/midplate ST-10 in my 66. Check out the track video in my sig, that's a 4200rpm launch off the two step on slicks. It seems to be holding up well, I know the Muncie I took out wouldn't hold up to that abuse, then again it is 30+ years old.
Although the car did spin on that run, I have put the trans though some abuse both on the track and on the street. I have yet to have any problems with it.
Based on my experiences so far, I wouldn't hesitate to use a St-10.
Brandon
1966 SS396 Chevelle
427 11:1 rect.heads
4 speed 3.90 posi
1967 Chevy Biscayne 2 dr.
350 th-350
3.55 posi
videos
RatONaStick at idle
RatONaStick on the road
RatONaStick at the track
RatONaStick is offline
post #10 of 28 (permalink) Old Sep 14th, 06, 3:34 PM
The St-10 and Muncie share the same syncros and sliders. One hub is the same, the other hub(I forget which) is the same except for the inner part where it goes on the main shaft.
The Muncie is no stronger in this area than the St-10.
post #11 of 28 (permalink) Old Sep 14th, 06, 3:50 PM
Jason
My understanding was the majority of the st10's were aluminum and warranty issues with performance cars such as the TA and z28 were the reason they even started using the cast iron, ironically most vettes still retained the aluminum case.
TC#2693
Aces# 7467
Heart of Dixie CC
136679ss is offline
post #12 of 28 (permalink) Old Sep 14th, 06, 4:05 PM
I've read something similar. From what I understand the 3.42 first transmissions were having durability issues and BW started to use the iron case/midplate on these units to help strengthen them. I know that my 904 case/iron midplate were from a 3.42 first trans, strange though I was told it was out of a Vette.
The durability issues have to do with the 3.42 gearset, you'll notice that the 3.42 first trans is the weakest of the bunch. If you've ever seen a 3.42 input shaft, the gear itself is tiny. There just isn't a whole lot of material there.
post #13 of 28 (permalink) Old Sep 14th, 06, 5:04 PM
Jason
That's because corvettes would never have had a factory 3.42 gearset only 2.34 -2.88.
I've found a great homepage that details a lot of good information on the ST10
http://fiedlerh.home.att.net/BW.htm
TC#2693
Aces# 7467
Heart of Dixie CC
136679ss is offline
post #14 of 28 (permalink) Old Sep 14th, 06, 5:17 PM
Wally
Guest
Posts: n/a
I don't believe I said the trans was not up to the task, just that they have a pulished low torque rating for current production units.
The best ST-10 units were never put in production cars, the iron case units you could buy from speed shops. They are the ones available with high nickel gears and ratios no higher than 2.88 low gear. All the other stuff came later when GM starting using the trans and when Richmond took over production.
The corvette used a iron case ST-10, some time after the end of the Muncie run and I think in some of the Z cars, not sure of the years.
If there is a weak part of the ST-10 its on the front of the main shaft, that little spud that sits in the roller bearings in the back of the input. I've seen a number of those break in race car applications and high HP heavy street cars that hook.
Most of you missed the point I was trying to make, that torque and HP ratings don't mean jack
post #15 of 28 (permalink) Old Sep 14th, 06, 6:29 PM
Wally
I know you werent saying they weren't up to the task, that first paragraph was directed to you, the rest was intended for the original poster. I probably should have made myself more clear.
It seemed that you were implying that those torque ratings were for the iron case versions, evidently I misunderstood you. Although it would be interesting to know how much the iron case adds to the strength of the transmissions. I can tell you one thing, the iron case/midplate sure adds some weight to the trans!
I remember you mentioning the mainshaft spud before. While I agree it may be a weak point, I tend to think that if a Super T10 will break in those situations you mentioned, so will a Muncie. Wouldn't you agree??
I know that if I were going to build a race car or a heavy high hp(we're talking mucho torque) street car, I wouldn't use either trans.
Brandon
1966 SS396 Chevelle
427 11:1 rect.heads
4 speed 3.90 posi
350 th-350
3.55 posi
videos
RatONaStick at idle
This Thread is more than 3908 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
super T10 in 70 chevelle chev-man Transmission & Driveline 3 Aug 29th, 06 7:34 PM
502/450hp crate motor: How much will 2.0" Hooker Super Comp hurt power over 1.875"? ss502 Performance 8 Nov 1st, 05 8:02 PM
Super Charging and power brakes? mike69ss Chevelle Tech 13 Sep 4th, 05 1:41 PM
Sold the T350, in goes the Super T-10 Surfin' 66 Transmission & Driveline 1 Jun 19th, 05 4:19 PM
Updates on all Chevelle cruise? notstock71 Team Chevelle Cruiz-ins 6 May 3rd, 05 10:21 PM
