What are the symptoms of a bad or loose pilot bearing? - Chevelle Tech
post #1 of 11 (permalink) Old Jun 14th, 06, 10:02 PM Thread Starter
Ron
I have a clunck when I let off the gas at low speeds. If I tap the gas lightly it cluncks again. I'm pretty sure its coming from the trans, could a loose or bad pilot bearing cause this? It's with my Tremec 5 speed.
Ron
70 Chevelle SS396 (496) Straub roller, M21
69 Malibu convertible
TC #54 Gold
69 - Top down
69 Top up
new wheels
70 side
On Gearz
ToocoolZ28 is offline
post #2 of 11 (permalink) Old Jun 14th, 06, 11:00 PM
Re: What are the symptoms of a bad or loose pilot bearing?
Ron
Check the U joints and suspension parts first. A bad pilot bearing won't clunk but will cause other problems like vibrations and hard shifting.
GMJim is offline
post #3 of 11 (permalink) Old Jun 14th, 06, 11:35 PM Thread Starter
Ron
Originally Posted by GMJim
Ron
New U-joints, all new suspension, ALL new clutch and every piece of linkage, driveshaft is not hitting the floor. I'm stumped.
TC #54 Gold
69 - Top down
69 Top up
new wheels
70 side
On Gearz
post #4 of 11 (permalink) Old Jun 15th, 06, 7:58 AM
a friend has a 66 chevelle w/TKO600.
same clunk situation.
we found the spider gears had excessive wear.(open rear).
replaced the gears and all is good now.
david
6t7gto is offline
post #5 of 11 (permalink) Old Jun 15th, 06, 9:24 AM
Wally
Guest
Posts: n/a
Ron
How much backlash is there in the rear????
post #6 of 11 (permalink) Old Jun 15th, 06, 1:58 PM
Send a message via MSN to Tkimble01
Get Under The Car With It In Park And Try To Move The Drive Shaft. It Sounds Like U-joints Or Rear End Gears.
Tkimble01 is offline
post #7 of 11 (permalink) Old Jun 15th, 06, 2:10 PM
The symptom of a bad pilot bushing is clutch chatter. Once the clutch is engaged, the pilot bushing cannot be responsible for clunking sounds. The u-joints or worn rear end gears are the most likely candidates.
tedixon is offline
post #8 of 11 (permalink) Old Jun 15th, 06, 3:54 PM
we're new to the TKO transmissions.
where is "PARK" on the shift pattern.
we've been looking ever since this was posted.
david
6t7gto is offline
post #9 of 11 (permalink) Old Jun 15th, 06, 7:02 PM Thread Starter
Ron
Nope, its definetly in the transmission, no doubt about it.
Thanks anyway.
Ron
TC #54 Gold
69 - Top down
69 Top up
new wheels
70 side
On Gearz
post #10 of 11 (permalink) Old Jun 16th, 06, 12:53 AM
david
hahahahahahahahaha! Good catch!
I believe its kept under lock and key in the glove box. Something about "TOP SECRET"
charbilly2001 is offline
post #11 of 11 (permalink) Old Jan 21st, 09, 3:13 PM
Andy
Send a message via Skype™ to Holey Moley 64
Sorry, I dont mean to bring up such an old topic, but I have the same situation. Tremmic T5 . I have been having a clunk from the mid to rear of the car (behind seat) whenever I put the clutch in to shift. It becomes less noticable with each increasing gear. I had a stock rear in, and it was quite noticable, then I swapped in an entirely different axle with a shorter gear and it was not as noticable but still presant. The clunk has persisted through shock+bushing replacement, new springs, a new yoke, new u-joints, new tranny mount, and now the rear. Any suggestions?
This is not the my truck in my signature. An 89 mustang is the car in question if that makes a difference.
-Andy
1979 Malibu
383, 200-4r
AFR195
60122 Lunati
9" 3.90
"The great proof of madness is the disproportion of one's designs to one's means." - Napoleon Bonaparte
Holey Moley 64 is offline
This Thread is more than 3021 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Confirmation of high volume pump causing loss of pressure @ 4750 rpm! Unclepennybags Engine 40 Aug 22nd, 08 10:38 AM
Clutch or Pilot bushing seized up, how to break loose? cody Performance 10 May 19th, 06 7:59 AM
Bearings loose Autoengineer Chevelle Tech 23 Jan 23rd, 06 2:05 PM
1 More Pilot Bearing Replacement Question.... Tintop55 1999 -- 2 Dec 17th, 99 9:11 PM
Pilot bearing Replacement.... Tintop55 1999 -- 11 Dec 13th, 99 11:12 AM
