1970 Muncie 4-speed TRANSMISSION?? or - Chevelle Tech
post #1 of 4 (permalink) Old Sep 18th, 05, 3:50 AM Thread Starter
Question 1970 Muncie 4-speed TRANSMISSION?? or
Hey gang. Whats up? Im new to this fourm and would love some intput on this subject matter if anyone is kind enough to do so. I have a 1970 Chevy Nova SS and I require a transmission. What would you guys recommend?
ahaban1931 is offline
post #2 of 4 (permalink) Old Sep 18th, 05, 4:21 AM
Re: 1970 Muncie 4-speed TRANSMISSION?? or
engine specs? Rear gear? What you already have? your goals for the car? Usually the base th350 is perfect.
1965 Chevelle Malibu SS.
www.livermoremuscle.com :: For my car
Years away from being my 8-71 blown 540, TKO 600, 4.11 and 4 wheel disc brake monster.
Adman is offline
post #3 of 4 (permalink) Old Sep 18th, 05, 12:35 PM
Talking Re: 1970 Muncie 4-speed TRANSMISSION?? or
if your asking about trannys i think for a mild small block th350 for an auto is fine , though behind the stroker i cracked two cases and eventually went to a turbo 400 wich i think if your going to go street strip its the way to go . 4 speeds are great but there are some weak ones out there . a muncie will put up with abuse but it seemed when i started to hook is when it broke (m20) .m22 rockcrushers seem to be tough but expensive and hard to find parts for. . i went to a super t10 out of an older trans am (26 spline input shaft) and it seems to work well . i had a cast iron three speed that i couldnt kill , since it had no fourth in it i suppose it left room for larger stronger gears from the factory ? but i still prefer a 4 speed with reverse in the tail . no saginaw four speeds they make hemselves into soup the first good launch
Dustinyork is offline
post #4 of 4 (permalink) Old Sep 18th, 05, 1:53 PM
Wally
Guest
Posts: n/a
If racing and sticky tires are in your future, then consider a automatic. They are far easier on parts than a stick car and are more tolerant of a bad setup. A stick car needs a good suspension, no wheel hop and bullit proof parts.
But if the street is your thing with a blast at the track every now and then you can't beat a stick for fun factor. Parts for any muncie are available new, not hard to find at all. There are also new gear sets for muncies now, M22 wide ratio and a M21 wide, not just another M20.
Every part of a Muncie had been reproduced and most of the new parts are much stronger than the originals.
This Thread is more than 4240 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Wally - Muncie 5 Speed Update? LS_5 Transmission & Driveline 71 Nov 10th, 10 3:21 PM
TH400 to a Muncie 4 SPEED PE TCHR Transmission & Driveline 7 Dec 18th, 03 8:38 AM
Muncie help 69velle Transmission & Driveline 3 Dec 22nd, 02 10:28 PM
Muncie 4 Speed Linkage JMiddione 1999 -- 1 Aug 19th, 99 8:46 PM
Need help identifying a Muncie 4 Speed Donny Moore 1999 -- 4 Jan 1st, 99 6:32 PM
