in
this forum
in
the entire site
Cancel
Login / Join
What's New
Forum Listing
Products
Marketplace
Showcase
Gallery
Members
FAQ
Dark Mode
Light Mode
menu
Log in
Sign up
Home
Forums
Chevelle Mechanical
Transmission & Driveline
Follow Forum
Create Thread
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show:
Loading…
1
1 of 559
Go to page
Go
559
D
Sticky
Bell Housing dial in
dream66
Aug 25, 2014
31K
Oct 27, 2023
by
v8440
Sticky
This is the why/how I always install a magnetic drain plug in Muncies
DZAUTO
Apr 18, 2012
45K
Aug 1, 2023
by
DZAUTO
Sticky
Importance of driveline angles
69-CHVL
May 29, 2021
15K
Nov 23, 2022
by
Lew540
G
Sticky
1966-67 Z bars clutch rods, OEM & Repop / 1964-72 Hydraulic vs Mechanical Clutches & 1964-72 Hydraulic Under DashSystem, T56 Install- Parts Swap, TKX
Gary 396
Sep 16, 2011
69K
Nov 7, 2022
by
Gary 396
Sticky
Elec switch for backup lights on a Muncie
DZAUTO
Sep 3, 2012
63K
Apr 25, 2022
by
427L88
Sticky
Course 101 on Bell housings/Flywheels with photos
DZAUTO
Aug 31, 2006
5
80
142K
Jun 23, 2021
by
Ramrod 1
Sticky
Eaton Posi rebuild
big gear head
Sep 2, 2012
50K
Nov 13, 2020
by
big gear head
Sticky
Converting a 68-72 from auto to 4sp with pictures
DZAUTO
Jul 18, 2012
71K
Sep 20, 2017
by
DZAUTO
Sticky
New Ring and Pinion Break In Procedure
Lionel-n-Chevelles
Sep 9, 2014
Locked
23K
Jan 14, 2016
by
70SSTHUMPER
G
Sticky
Rear End Installation - Step By Step - With Pictures
Greg
Mar 29, 2011
81K
Sep 17, 2015
by
ragtop6t8
Sticky
How to adjust a shifter.
LevonH
Feb 18, 2014
Locked
0
19K
Feb 18, 2014
by
LevonH
12 bolt gear install problems
68Chevele
Dec 16, 2023
25
1K
2d ago
by
68Chevele
B
Gear ratio
bringo
5d ago
26
656
3d ago
by
mrpaticular
S
saginaw trans overdrive
steve67
Aug 11, 2009
14
2K
4d ago
by
MidLife72
Installing TV cable seal
richiecat4223
4d ago
5
115
4d ago
by
Gillis
D
Turbo 400 transmission mount
dannoman
5d ago
4d ago
by
dannoman
Remove Cross Pin Shaft
fjohndiv
Mar 4, 2024
12
589
5d ago
by
bracketchev1221
M
Proper connection for transmission cooling lines?
MFD
5d ago
7
270
5d ago
by
MFD
THM-350 Fluid Question
GeneF
6d ago
13
332
5d ago
by
mrpaticular
T
72 Column shift rod too short
TheBoatWhisperer
Mar 12, 2024
4
188
6d ago
by
caminonut
10 bolt or 12 bolt rear end
cre8ingalegacy
Mar 7, 2024
1K
6d ago
by
GM man
Transmission crossmember
Milan3056
Mar 12, 2024
6d ago
by
mrpaticular
700R4 external pressure switch
richiecat4223
7d ago
1
81
6d ago
by
dyno jonn
M
Clutch fork spring '70
mrandig_8215
Mar 9, 2024
4
209
6d ago
by
JIM
R
1969 Chevelle Axle Yoke Question
RMBillings
Mar 11, 2024
7
240
6d ago
by
schovil69
Tranny crossmember
Milan3056
Mar 12, 2024
0
65
Mar 12, 2024
by
Milan3056
J
anyone know early hurst shifters?
Jim Mac
Mar 9, 2024
8
380
Mar 12, 2024
by
Jim Mac
E
eBay 8.2 posi unit
Emoeller
Mar 10, 2024
7
245
Mar 10, 2024
by
68Chevele
Looking to install 700R4 lock up parts
richiecat4223
Mar 9, 2024
Mar 10, 2024
by
richiecat4223
American Powertrain Hydraulic Clutch
BobinPA
Mar 9, 2024
4
187
Mar 10, 2024
by
NickeyChevelle
New 12 bolt rear end recommendations please
Lcode70
Mar 6, 2024
1K
Mar 10, 2024
by
rpol78
L
1971 Chevelle Differential Code Help
LearJet74
Mar 9, 2024
1
158
Mar 9, 2024
by
Livin70
4l60E Fitment on a LS3
Jonesmen
Mar 7, 2024
5
293
Mar 8, 2024
by
Diabel1969
This is dumb question
richiecat4223
Mar 7, 2024
Mar 8, 2024
by
mrpaticular
Which flexplate
mrpaticular
Mar 5, 2024
13
309
Mar 8, 2024
by
mrpaticular
S
'69 SS Clutch Z-bar correct Frame Bracket location?
Squink1
Jan 17, 2019
16
7K
Mar 7, 2024
by
68 Chad
6
TH200-4R$$$$?
67malibu4drHT
Jun 7, 2023
16
1K
Mar 6, 2024
by
von
T
Is this a GM 10 bolt 8.5, or a BOP?
tipetu
Mar 3, 2024
12
485
Mar 4, 2024
by
tipetu
S
Running transmission backwards?
Steve67L-79
Mar 1, 2024
14
663
Mar 3, 2024
by
sr530
64 Malibu SS Convertible Transmission Factory
xk49
Mar 1, 2024
5
252
Mar 3, 2024
by
David Bates
6
GM 8.2 Posi install / contact pattern opinions?
68LSXelco
Feb 29, 2024
Mar 1, 2024
by
68LSXelco
T
454 Gen V - Which flywheel do I choose..
tipetu
Feb 29, 2024
Mar 1, 2024
by
tipetu
Tci Transmissions and tail housing
aza
Feb 27, 2024
9
440
Feb 29, 2024
by
68Chevele
Date code chart 700R4
richiecat4223
Feb 27, 2024
16
326
Feb 28, 2024
by
396325
hurst shifter hitting dash ??
fnoblitt
Feb 22, 2024
11
605
Feb 28, 2024
by
fnoblitt
A
65 M20 Clutch Release Issues
abarnett
Feb 20, 2024
28
832
Feb 27, 2024
by
abarnett
1
1 of 559
Go to page
Go
559
155.2K
posts
47.8M
views
Transmissions and Differentials
Show Less
Join Community
Grow Your Business
Forum Staff
View All
LevonH
Super Moderator
Rich-L79
Super Moderator
Bob Tiley
Super Moderator
Top Contributors this Month
View All
G
GM man
mrpaticular
123pugsy
Recommended Communities
AVS Forum
1M+ members
SkyscraperCity
880K+ members
Deals Forum
40+ members
Home
Forums
Chevelle Mechanical
