64 upper radiator hose - Chevelle Tech
post #1 of 6 (permalink) Old Feb 16th, 17, 6:25 PM Thread Starter
MATT
For the life of me I can not find the correct upper radiator hose for my 64 ss small block. I have a correct dewitts radiator with passenger side inlet and my thermostat housing is a front facing 45 degree. Anybody?
THAT1GUY is offline
post #2 of 6 (permalink) Old Feb 16th, 17, 6:40 PM
Tim
Re: 64 upper radiator hose
I got one at Ground up.
1964-1965 Chevelle Small Block Upper Radiator Hose
spinshop is offline
post #3 of 6 (permalink) Old Feb 17th, 17, 8:20 AM Thread Starter
MATT
I will take a picture this afternoon of my setup but the hose you sent appears to be missing a bend with regards to my layout. The inletspecs face each other but are offset in elevation and left to right.
THAT1GUY is offline
post #4 of 6 (permalink) Old Feb 17th, 17, 10:50 AM
Tim
Maybe you have the wrong thermostat housing?
Here`s mine.
spinshop is offline
post #5 of 6 (permalink) Old Feb 17th, 17, 11:41 AM Thread Starter
MATT
Thanks Tim, the housing is definitely the problem. I searched aLloyd over for a passenger facing housing that wasn't a swivel and couldn't find one so I went with the straight forward that kept coming up on all my searches. Where did you get your housing?
THAT1GUY is offline
post #6 of 6 (permalink) Old Feb 17th, 17, 1:56 PM
Tim
It came original on the motor.
Maybe your local junk yard?
spinshop is offline
