67 Heater Box ?? - Chevelle Tech
post #1 of 2 (permalink) Old Jan 7th, 17, 7:27 AM Thread Starter
Jordan
67 Heater Box ??
Hello my car was originally an A/C car but someone pulled everything out years ago and installed an Non-A/C heater box on the firewall. Now inside the car I still have my A/C kick panels and what seems to be the original heater core door under the dash and a heater assembly unit without A/C under the radio. I'm looking to put some heat back into this Chevelle but I was wondering if I have to buy a new box under the dash for a Non-A/C car or can I just take the assembly off of the firewall then install a new heater core and blower motor if necessary.
A Chevy Can Only Be A Chevy.
1967 Chevelle 4-Speed
JROCK142 is offline
post #2 of 2 (permalink) Old Jan 11th, 17, 11:19 AM
benny
Re: 67 Heater Box ??
Id look to how they worked the firewall under the fender. In an ac car there is a bog hole there where the evap case goes. If they did everything right just need to change blower motor and heater core as mentioned
obsessedw/musclecars is offline
