66-67 chevelle electic fan pics (2000 Ford Contour Fan) - Chevelle Tech
post #1 of 15 (permalink) Old Apr 11th, 10, 3:29 PM Thread Starter
Send a message via AIM to Pro67Chevy
I've been getting a few requests for the electric fan setup I put together. I attached a few pics of the installed radiator setup for my '67. I've also attached the drawing I designed for the wiring.
I ran the car for a couple hours the other day in 80* weather. The temps on my BBC never went over 160*! (I had the fan on manually, thermo switch isn’t working).
Radiator: Two row design. 1" tubes. (24x16 core)
Fans: 2000 Ford Contour fans. Dual 12” fans with shroud. (24.2" x 15.8" x 3.3") Dorman Part # 620-104.
Hope this helps all those looking for a “cooler” setup.
Jim M.
'67 Velle
468
th-400
12-bolt,4.10s
My Chevy...
The Velle 468 Int
"It's all in the smoke!"
Video 1 Video 2
No time slips yet, 2013!!!
Pro67Chevy is offline
post #2 of 15 (permalink) Old Apr 11th, 10, 4:17 PM
Vince
Re: 66-67 chevelle electic fan pics (2000 Ford Contour Fan)
thats a nice looking set-up.
about the wiring diagram- are there any merits to wiring 1-fan to come on at 180* and the other at say 195* to reduce the electrical load if not needed???
VinceS427bb is offline
post #3 of 15 (permalink) Old Apr 11th, 10, 4:44 PM Thread Starter
thank you.
Vince, with the twin fan setup there are any numper of possibilities as you described. I went with the easiest wiring configuration.
I also don't like to see anything over 190*. That's just a personal thing.
Jim M.
'67 Velle
468
th-400
12-bolt,4.10s
My Chevy...
The Velle 468 Int
Video 1 Video 2
post #4 of 15 (permalink) Old Apr 20th, 10, 3:21 PM
that looks very nice!
was wondering if you could tell me the overall dimensions of the radiator?
cap to bottom, left to right and thickness.
thanks
Torq is offline
post #5 of 15 (permalink) Old Jul 12th, 10, 12:01 PM
Thanks for the info. I went to the U-pull and found one from a 98 and fits great on my 64!
Enganeer is offline
post #6 of 15 (permalink) Old Jul 12th, 10, 5:04 PM
Paul
Any idea the cfm of those fans? I would like to know the thickness of your rad also...
454/T400/9" in a 67 Beaumont
Paul-ish is offline
post #7 of 15 (permalink) Old Jul 12th, 10, 8:08 PM
The contour fan pulls 3400 cfm. The Taurus fan pulls around 3800 cfm for reference.
The radiator is around 3" thick and I mounted it to the front support.
Enganeer is offline
post #8 of 15 (permalink) Old Jul 13th, 10, 1:18 AM
Paul
Thanks for the cfm rating...I need the size of Pro67's rad though.
The engine compartment from 64/67 are diffrent and im looking for the specific application.
Paul-ish is offline
post #9 of 15 (permalink) Old Jul 30th, 10, 12:23 AM
Nice set up!! I have the same radiator in my 67 but went to a serpentine setup dont know if i have the room for those fans?? used the long waterpump.
NO5.0 is offline
post #10 of 15 (permalink) Old Jul 30th, 10, 12:29 AM
Sean
nice. how thick are the fans measured from the radiator face?
Sean
'65SS, 385ci, AFR 195's, Comp XR 288HR, Forged bottom end, TKO600, 3.73/12 Bolt
Now in our new home in Tucson AZ
http://spotted.stripes.com/galleries....php?id=337573
"Aint no fun 'till somethin gets broke!"
troposcuba is offline
post #11 of 15 (permalink) Old Jul 30th, 10, 12:52 AM
Ron
A single 40 amp relay might be too small for the application. You might check on that.
Very nice mounting of the fan assembly! Well done.
Ron
bikeron is offline
post #12 of 15 (permalink) Old Jul 30th, 10, 5:39 PM
I just got my set from dorman (rockauto)... was wondering if you wired them for different speeds.. it apears the units have a current limiting resistor in the housing.
was considering wireing the fans in parallel for max fan and in series for moderate cooling (speed) but then saw the resistor in the unit. Also included what looks like a diod which might to prevent back feed while they coast to a stop. I'm going to look at my neighbors contour to see how his wireing goes. (although his is a 4 banger so might have a different fan then this dual one).. Another guy down the street had a SVT so might be able to look at his to.
b.
wcarrothers is offline
post #13 of 15 (permalink) Old Jul 26th, 12, 5:47 PM
Doing some research and found this thread. I was wondering if anyone has tried this fan as a pusher or if it can be wired to do so?
jch1805 is online now
post #14 of 15 (permalink) Old Jul 27th, 12, 4:07 PM
Reply to older thread:
I run with the Derale 16789 high-amperage adjustable dual fan controller with a pair of Maradyne M122 puller fans with no issues.
http://www.maradynehp.com/products/champion/m122.php
Fan #1 comes on at set temp then fan #2 comes on 10deg warmer than fan #1.
Turn off temp is 10deg below turn on temp.
Max draw 35 CONTINUOUS amps per fan. But will not work on Lincoln mark VIII and ford Taurus, dodge viper..
Heck here is install inst:
http://inet.derale.com/clientdocs/1_328.pdf
1st project 67 chev sedan, long gone.
2nd project 64 malibu SS 327 4spd major regret in selling for next project
3rd 56 chevy, my to be drag car sold for current.
Current 65 impala ss, bbc 427 with auto gear m22 4spd
65 Imp SS is offline
post #15 of 15 (permalink) Old Sep 7th, 12, 6:00 PM
Anyone know how much current the contour fans draw?
'67 Elky - 496 / TH400
"Democracy is two wolves and a lamb discussing what's for dinner. Freedom is a well armed lamb contesting the vote" Benjamin Franklin
http://www.picturetrail.com/gallery/...6593&members=1
phocksphyre is offline
