68-69 Vintage Air Defrost Ducts Don't Fit - Chevelle Tech
post #1 of 10 (permalink) Old May 29th, 09, 1:59 PM Thread Starter
Jason
Anyone else wonder how the hell the clips for the defrost ducts fit on the Vintage Air for a Non AC car??? There is no way in hell these are going to fit. ARGGGGGHhH
69 540 FAST EFI BBC El Camino"it's alive"
http://profile.imageshack.us/user/peetsjunkie/images Check out the latest stuff here!
ss396boy is offline
post #2 of 10 (permalink) Old May 29th, 09, 2:37 PM
Re: 68-69 Vintage Air Defrost Ducts Don't Fit
Clips for the duct to defroster or deroster to the dash? It's been several years since I did my car? I know I was able to get the defroster mounted to dash OK but I ended up using duct tape to hold the duct to the defroster. Make sense?
TC #364
Aces #4309
Chevelle's appeal to two age groups. Under 30. And over.
Daytona Jeff is offline
post #3 of 10 (permalink) Old May 29th, 09, 2:39 PM
What speed rating was the duct tape?
Stalkingbear is offline
post #4 of 10 (permalink) Old May 29th, 09, 2:43 PM
Generic 200mph
TC #364
Aces #4309
post #5 of 10 (permalink) Old May 29th, 09, 3:35 PM Thread Starter
Jason
Defroster to dash. Comes with clips that are supposed to attach somewhere where there is no metal.
I understand the duct tape part
ss396boy is offline
post #6 of 10 (permalink) Old May 29th, 09, 3:57 PM
Shoot Jason, I can't picture them anymore? Been to long. I do remember thinking after I got it all put back together that I didn't like the looks of VA defrosters from thru the windshield.....they still the oblong plastic with round holes in them? I should have tried to connect the duct to the factory defroster piece. Is that an option for you?
TC #364
Aces #4309
post #7 of 10 (permalink) Old May 29th, 09, 4:35 PM
Yup they don't fit for S--T. Not without a LOT of work AND creativity. If I recall correctly the outlests supplied by VA are LAME at BEST. Make that VERY LAME!
My suggestion is to fabricate your own outlets. Vintage makes some "ends" that the flex hose mounts to. The ends are for use in Street Rods but they can be used as a compoment of a custom made outlet unit. I fabricated my own unit for my 72.
I know that you are talking about a 68 / 69. Don't get too hung up about the difference between the 68 /69 cars and the 70 / 72 cars. Yes there are differences everywhere in the years BUT up there by the firewall they are more or less the same from 1968 thru 1972. Someone is gonna chime in here and talk about every little difference and YES there are differences BUT you are likely faced with fabrication no matter what you do. As you already said the VA parts don't fit !!
Someone recently told me that you can get a pretty well made defroster duct from Vintage for the later 70 ...72 A-body cars.
You don't say what unit you are installing the "Sure Fit" or Gen II or whatever. It makes no real difference because all the VA stuff uses flex hose to get the air up to the windshield so fabricating something with the Street Rod parts I mention above is likely a good alternative. Look at the VA unit for the 70 / 72 cars before you get too involved in fabrication however.
oman is offline
post #8 of 10 (permalink) Old May 30th, 09, 11:33 AM Thread Starter
Jason
Ya this is a "Sure S#it" system ..... I like also how they say you have to use the binary switch but don't tell you where it's supposed to be installed in the system...hahaahah nice one!
ss396boy is offline
post #9 of 10 (permalink) Old May 30th, 09, 12:54 PM
I have pictures of the Vent / Defroster outlet I rigged up if you want them. Need an E-mail address and I can forward them to you.
oman is offline
post #10 of 10 (permalink) Old Jun 3rd, 09, 12:40 PM
TC
Lifetime Founding Member
Terry
I had the same problems, I just riveted the tubes into the OE defrost duct work and made an alum. plate to seal it at the bottom .
I also put some black sealer to make sure it was sealed.
I have some pictures on my web site, Under interiors #2 http://my.att.net/p/s/community.dll?...eid=256928&ck=
I also have a few pictures in my showroom.
I think I cut up the VA vent to get the hose ends?
Hope this helps?
T.C.
1969 two door sport coupe with "SS" option.
Dark blue with parchment interior.
468/comp XE284, TH 400 W/2800 Stall, Gear Vendors Overdrive, 373 12 bolt
terry.cowger@yahoo.com
http://www.chevelles.com/showroom/sh...00/ppuser/1190
TC is offline
This Thread is more than 2942 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
