Heater Core - Chevelle Tech
post #1 of 2 (permalink) Old Jan 21st, 08, 5:36 PM Thread Starter
Heater Core
71 Elco with BB and AC. Heater core is starting to leak. Any help on how to change it. Does it need to come out from the engine side or inside?
442 Harv is offline
post #2 of 2 (permalink) Old Jan 21st, 08, 6:25 PM
Pete
Re: Heater Core
If it's anything like a '70', and I assume it is, comes out from inside. You have to remove nuts on the engine compartment side. An assembly manual really would help here and also a search would yiels a ton of info. Good luck Pete
Member# 1097
1970 Chevelle 350cu w/ th350, 750 edel carb, perform intake and lopey cam of unknown specs which produces low vacuum 7-9", otherwise stock motor.
67 std Camaro conv, 1978 Corvette, 03 Silverado, 13 Sonata Hybrid
http://s62.photobucket.com/albums/h8...t=DSC01103.jpg
no1dc is offline
