What would keep my Linksys wireless router from assigning an IP addres - Chevelle Tech
Bug Hunt Computer related problems
Virus warnings - Technical help.
post #1 of 18 (permalink) Old Feb 23rd, 12, 9:06 PM Thread Starter
I have a Linksys BEFW11S4V.2 wireless router and I have to keep it unsecured or else the wireless will not work.
We can log in with the password and it says it is connected but with limited or no conductivity.
If I hit repair, it says it is renewing IP Address but then finally says it can not assign the computer an IP address.
My twin granddaughters want to get their Ipods online and also the laptops from time to time but the wireless only works if I have the WEP key disabled.
I would like to keep it secure but this stuff is so far over my head with all the "dhc" and whatever long list of "initials" settings I'm totally lost.
As far as I know, I haven't had any problems leaving the wep disabled and if any neighbors are using it, I can't tell it unless maybe that's why some videos are slow and have to stop and restart several times.
Anyone that knows about this stuff have any ideas?
post #2 of 18 (permalink) Old Feb 24th, 12, 4:55 PM
Rod
Re: What would keep my Linksys wireless router from assigning an IP ad
I was having the same problem a few days ago. My laptop would say it was connected but with no internet service. It was saying my IP address was not correct. Don't think my router is the same as yours, but I fixed mine by unplugging the router and leaving it unplugged overnight. The next day when I plugged it in, my connection was fixed. Not sure why, as I had reset the thing several times and that did not fix it but just shutting it down did. Good luck.
ACES Member
http://www.chevelles.com/forums/members/30920-6970chevelle-albums-my-chevelles.html
'69 Chevelle SS 396/325 Matching Numbers w/factory docs
'70 Chevelle SS 454/360 LS5-SOLD
6970chevelle is offline
post #3 of 18 (permalink) Old Feb 24th, 12, 4:58 PM
Unplugging just for a few minutes will normally clear any problems with the linksys routers. I usually do this about once a month, mine is the old blue one with 2 removable antennas.
Boldly going nowhere
72 Concours Wagon More go, more whoa and lots of creature comforts
64 Nova 400 series
Team Chevelle Gold Member #42
Philip is offline
post #4 of 18 (permalink) Old Feb 24th, 12, 5:05 PM
The Fat Stig
Linksys routers are crap. We were replacing them annually at the office before I realized the problem.
Buy a different brand.
Originally Posted by jpete, Dean, Derek69SS, hoffbug, rubadub, Grandsport, Thomas Jefferson, 1badss396, MEJ1990TM, and mrdjc99
As usual, Andy is right
If it doesn't fit, force it. If it breaks, it needed to be replaced anyway.
SuperAndy's Garage
Automotive Archaeology
Andy69 is online now
post #5 of 18 (permalink) Old Feb 24th, 12, 5:10 PM
Anhtuan Le
Dean, the "thing" that assigns your ip address is the DHCP option. This must be "on". How old is the router? They do get hot, and they do burn out.
You could always try doing a factory reset, there's a hole on the front or back of the router, push that in and count to 30 or so and release. see if that helps.
atle is offline
post #6 of 18 (permalink) Old Feb 25th, 12, 11:15 AM
Dale
Any brand of router can go bad. I've used Lynksys for a number of years at home without problems. I recently bought a Netgear wireless router out of necessity due to a change in my home network to a faster N wireless speed. I have mine set up to limit access by MAC address. Only real compaint I have with it is I have to reboot the router when I add a new device, something I did NOT have to do with the Linksys unit. I still use me linksys hub though for hard-wire connections.
DaleM is offline
post #7 of 18 (permalink) Old Feb 25th, 12, 8:06 PM Thread Starter
I'll have to try unplugging it and see what happens.
I haven't done that in quite a while now and I used to have to unplug it a couple of times a day to reset it then I figured out all I need to do is type 192.168.1.1 and log on then it works again.
I wish I wasn't so thick headed and could learn all this stuff.
post #8 of 18 (permalink) Old Feb 25th, 12, 10:21 PM
Levon
Hi Dean. The DHCP on the router can cause a little problem on occasion if you do not shut your computer off. What happens up here is that your router gets an IP address form the ISP. They "lease" the address for up to 30 days and if you do not shut your computer off occasionally, the lease expires and does not renew so you end up with a dead link to the ISP. With 6 computers in our house we usually get them all shut off at some point but the "boy" forgets sometimes and I end up doing the ruthless pre-emption (AKA Power Plug) to reset it. Ours is a D-Link.
Levon Hovagimian
Team Chevelle #279
70 Chevelle SS 454 LS5 4 speed.
1966 427 Corvette SOLD
Priddis, Ab. Canada
My Showroom
LevonH is online now
post #9 of 18 (permalink) Old Feb 25th, 12, 10:36 PM Thread Starter
Interesting but the laptop and iPods are shut off every day, the laptop several times a day.
post #10 of 18 (permalink) Old Feb 25th, 12, 10:43 PM
Levon
Recheck the settings in the router and see if DHCP is set to automatic. Some let you do automatic or manual. My Dlink is that way.
Levon Hovagimian
Team Chevelle #279
Priddis, Ab. Canada
My Showroom
post #11 of 18 (permalink) Old Feb 27th, 12, 8:36 PM Thread Starter
FIXED
Many thanks to atle!!!
http://www.chevelles.com/forums/members/52403-atle.html
I thought that my router log on password and the WEP key were one and the same.
post #12 of 18 (permalink) Old Feb 27th, 12, 11:09 PM
Anhtuan Le
anytime Dean !! any problems gimme a ring
atle is offline
post #13 of 18 (permalink) Old Feb 27th, 12, 11:47 PM Thread Starter
Granddaughter's iPods worked OK too Anhtuan
post #14 of 18 (permalink) Old Feb 28th, 12, 10:40 AM Thread Starter
Hey Anhtuan, remember that I didn't have a "wireless tab" before, well guess what I have one now.
post #15 of 18 (permalink) Old Feb 28th, 12, 11:48 AM
Anhtuan Le
weird!! probably only shows up when you activate the wireless security. good work, you are now a wireless expert.
atle is offline
