Positive Cable Turning Black - Chevelle Tech
post #1 of 4 (permalink) Old Aug 9th, 05, 6:27 PM Thread Starter
Steven
Well I replaced the the + battery cable on my 67 SS. I am running an alternator with ext volt regulator, one of the Wells volt regulator. Instantly cleared up some hot start problems I was seeing with the old, worn cable. Now, I may drive the car 1 week-end, and then it will sit a couple of weeks before I drive it again, if that matters. Anyway, the cable post is starting to turn black ... What is this a sign of ? Overcharging ??? A cheap cable ? This cable is a Pep Boys variety. Also, I do have A/C , and a stereo with amp. My alternator is a 63 amp size ... Do I need to step up the alternator? Can I go higher amps without going to an internal regulated type? Any and all comments and suggestions would be appreciated... Thanks ... Steven
sdtsdt is offline
post #2 of 4 (permalink) Old Aug 9th, 05, 6:51 PM
Hey You!
Re: Positive Cable Turning Black
Sounds like a chemical reaction. Almost like something is on the new battery cable post reacting with the battery. You could try cleaning it but by now it's probably stained.
Yo-ho Yo-ho a pirate's life for me.
John_Muha is offline
post #3 of 4 (permalink) Old Aug 9th, 05, 6:53 PM
Lead will turn dark over time. Is this happening so quickly to cause a problem? Don't know. If it gets really dark there may be some other root cause (like vapors escaping from the battery). Try a thin film of whit lithium grease to prevent it.
Zeke
67 Chevelle
64 Chevelle
90 Corvette ZR1
TC# 3094 ACES# 7297
zeke67 is offline
post #4 of 4 (permalink) Old Aug 9th, 05, 7:09 PM
Clint
I'm assuming that the insulation is not black. If the insulation is black, too, then you've got overcurrent: you need less load or thicker guage cable. Otherwise, it is a sign of electrolysis. Your posts are meant to be sacrificial so that your car's electrical cabling doesn't just crumble to pieces. They make pads that go around the posts to slow this process, but don't know how well they work.
Clint Turner
"Fly Navy"
jayhawkclint is offline
Positive Battery Cable Routing On A 1970 350 bbjhill Restoration Corner 0 Aug 9th, 05 10:55 AM
Help, adjustment for TV cable Glenn Transmission & Driveline 7 May 31st, 05 11:47 AM
Which GM throttle cable with 2004r? djw Transmission & Driveline 9 Mar 28th, 05 11:49 PM
200R4 tv cable adjustment tas Transmission & Driveline 5 Apr 26th, 04 10:55 AM
30 or 60 Degree Gloss Black Paint? curtls6 Body Shop 2 Feb 6th, 01 5:09 AM
