IGN Terminal on Fuse Block Not Getting Power - Chevelle Tech
post #1 of 10 (permalink) Old Dec 10th, 02, 5:29 PM Thread Starter
I recently had my HEI power wire hooked up to the IGN terminal on the fuse block. But now after I got the engine back in and wired up, there's no power to the IGN terminal when the key is on. Is their a fuse for that terminal anywhere or why wouldn't it work?
Trever Maas
TC Member #: 1432
1972 Chevelle Malibu
Mohave Gold
L65 350/M38 TH350
2.73 AXL RATIO
1948 Chrysler Windsor
Flathead 6/Semi-Auto
4 Speed Column Shift
Fluid Drive Transmission
"Both Undergoing Slow Restorations"
malibu man is offline
post #2 of 10 (permalink) Old Dec 10th, 02, 9:30 PM
Hey You!
Yes, it is fused but it does not have a separate fuse. That terminal uses one of the fuses in the fuse block. Believe it's the turn signal fuse (99% sure). Second from the bottom, right hand side. The connection between the two is on the rear of the fuse block.
John_Muha is offline
post #3 of 10 (permalink) Old Dec 10th, 02, 9:44 PM
Dale
It should be fused; at least the one on my 67 is. I don't have any schematics for a 72 wiring system but it but I'm sure someone here has one.
TC Gold #92/ACES #1709
67 SS & 67 Elky
GR8PMKN
Dale's Place Team 67
Midwest Chevelle Regional Governing Council
Integrity: If you have it, it doesn't matter - If you don't have it, it doesn't matter.
DaleM is offline
post #4 of 10 (permalink) Old Dec 11th, 02, 8:51 AM Thread Starter
Thanks!
I have a shop manual with a schematic but I don't know what to look for. I'll check that turn signal first.
Trever Maas
TC Member #: 1432
Mohave Gold
L65 350/M38 TH350
2.73 AXL RATIO
post #5 of 10 (permalink) Old Dec 11th, 02, 2:26 PM
Send a message via AIM to Billys68SS
One thing I have run across is the junction block where the wiring harness and the power wire to the battery connect. It should be right behind the battery close to the back of the headlights.
Billy
Billys68SS is offline
post #6 of 10 (permalink) Old Dec 11th, 02, 2:34 PM
Adam
Send a message via AIM to AdamLym
<BLOCKQUOTE>quote:</font><HR>Originally posted by Billys68SS:
Billy
<HR></BLOCKQUOTE>
Yup, had a loose wire there that had me looking all over the place.
Adam Layman
1971 Chevelle Malibu
My Webpage
Sophomore at Notre Dame
NEW WEBPAGE!
AdamLym is offline
post #7 of 10 (permalink) Old Dec 11th, 02, 3:24 PM
Hey You!
<BLOCKQUOTE>quote:</font><HR>Originally posted by AdamLym:
<HR></BLOCKQUOTE>
72 doesn't have a block behind the battery. The car is a little different than the other years.
post #8 of 10 (permalink) Old Dec 11th, 02, 4:12 PM
Adam
<BLOCKQUOTE>quote:</font><HR>Originally posted by John_Muha:
72 doesn't have a block behind the battery. The car is a little different than the other years.<HR></BLOCKQUOTE>
Thanks for the correction John, I didnt know that.
Some help I am
Adam Layman
My Webpage
NEW WEBPAGE!
AdamLym is offline
post #9 of 10 (permalink) Old Dec 11th, 02, 4:28 PM Thread Starter
It was the signal fuse. It works now.
Trever Maas
TC Member #: 1432
Mohave Gold
L65 350/M38 TH350
2.73 AXL RATIO
post #10 of 10 (permalink) Old Dec 11th, 02, 5:50 PM
Hey You!
Some help I am
<HR></BLOCKQUOTE>
Adam. You are a great help. The only advantage I have is that I've had my 72 for over 31 years. Couldn't find that block either the first time I looked for it. Also if you have a problem with that block you wouldn't have power on the BAT terminal either. The line on the block is the input line to the fuse block.
<BLOCKQUOTE>quote:</font><HR>Originally posted by malibu man:
<HR></BLOCKQUOTE>
Great. Another deed done dirt cheap.
This Thread is more than 5280 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
