68 convertible wiring diagram - Chevelle Tech
post #1 of 2 (permalink) Old Dec 31st, 03, 4:31 PM Thread Starter
Post
got my jim osborn wiring diagram manual and there is still no diagram for the tops electrics. sombody has got to have one.
gunderson.1 is offline
post #2 of 2 (permalink) Old Dec 31st, 03, 9:28 PM
Steamy
Post
The 1968 Fisher body manual doesn't have a diagram, but it does have checking procedures for the top. It appears that the only electrical components are the switch and the motor. The center terminal of the switch is the 12v feed, and the other two terminals go to the motor leads. It doesn't mention any wire colors at the switch. It says that the wires at the top motor are dark green, red, and a black ground. When the switch is on the "up" position, the red wire is hot, and when it's in the "down" position, the dark green wire is hot. This just reverses the motor to pump the fluid in two different directions. Just exactly what kind of problem are you having & maybe we can help??
BL
My Showroom
http://www.chevelles.com/showroom/sh...0/ppuser/15214
Ark68SS is offline
This Thread is more than 4866 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
