Pass. Side Frt Parking Lamp issue on 70 - Page 2 - Chevelle Tech
post #16 of 19 (permalink) Old Apr 7th, 12, 8:58 AM
Jason
Re: Pass. Side Frt Parking Lamp issue on 70
Success! Well, success insofar as I found out what the problem is.
This test worked. It is a bad ground.
Now...what is the permanent fix?
Thanks all!
Sounds like it might have a bad ground and there is an easy way to check that.
Using a fairly long piece of small gauge flexible wire, strip a couple of inches from one end and wrap/twist it around the bulb base near the glass. Install the bulb and hold the other end of the wire onto a known good ground.
jkratty is offline
post #17 of 19 (permalink) Old Apr 7th, 12, 12:16 PM
Get the socket grounded, what ever it takes to do it.
I would find out exactly where the bad ground connection is first.
post #18 of 19 (permalink) Old Apr 7th, 12, 1:20 PM
Jason
Sorry to be so ignorant, but electrical is not my strong suit.
How exactly do I go about doing this?
jkratty is offline
post #19 of 19 (permalink) Old Apr 7th, 12, 1:38 PM
I'll have to go look at a parking light assembly to follow the ground path to the socket since I can't remember.
Gear in this thread - Powered by O'Reilly Auto Parts
