'70 ss dash w/ gauges wiring diagram??? - Chevelle Tech
post #1 of 21 (permalink) Old Nov 4th, 09, 10:41 AM Thread Starter
Lance
I am trying to find a wiring diagram for my '70 SS dash with gauges???
This wiring diagram is not in my '70 GM service manual, '70 GM assembly manual, '70 Fisher body manual or in my Chiltons manual. Only idiot light dash wiring diagrams are shown in all of these???
Please help, as I am getting ready for the big "DASH PULL" this winter, to get all dash componets working again as they should.
ACES #08588
1970 Chevelle SS
1970 Olds 442 Survivor
1997 SVT Cobra Convertible
smoke' em II is offline
post #2 of 21 (permalink) Old Nov 4th, 09, 12:10 PM
robert
Send a message via AIM to monte7ocar Send a message via Yahoo to monte7ocar
Re: '70 ss dash w/ gauges wiring diagram???
It's fairly easy since there is a 12 pin plug which plugs into the dash and then the pcb takes care of the rest for the dash, all of the dash lights are the same bulbs.
monte7ocar is offline
post #3 of 21 (permalink) Old Nov 6th, 09, 2:19 PM Thread Starter
Lance
Does anybody even sell the wiring diagrams for '70 SS dash with gauges???
Not only would the dash wiring be different, but the "forward lamp" harness would be different with gauges as well.
I can't believe that none of my GM manuals or Chilton manual has the wiring diagrams for '70's with gauges???
ACES #08588
1970 Chevelle SS
post #4 of 21 (permalink) Old Nov 7th, 09, 11:19 AM Thread Starter
Lance
Where to buy wiring diagram information for a '70 SS with the factory gauges (non-idiot lights)???
Wire colors are different for the "dash harness" and "forward lamp" harness, than they are for a idiot light car.
ACES #08588
1970 Chevelle SS
post #5 of 21 (permalink) Old Nov 7th, 09, 12:40 PM
Gary
I would look farther into your Service manual. In my 72 manual, an addendum to the idiot lights wiring diagram are on page 12-76 figure 93 and 94
'72_Skunk is offline
post #6 of 21 (permalink) Old Nov 7th, 09, 6:33 PM
robert
I have a wiring book for a 70 Chevelle with the idot lights and SS center section. I've looked at both and its basiclly the same thing other then the SS dash having all 12 slots filled in the plug.
post #7 of 21 (permalink) Old Nov 8th, 09, 2:03 AM Thread Starter
Lance
Thanks Robert, but I was hoping that someone would make a more detailed wiring diagram for '70 SS dash with gauges.
There is alot of rigging behind my dash and many of my gauges don't work. I am trying to make sure that every thing is right before I install my newly rebuilt gauges.
Also the wiring colors for the "forward lamp" harness with gauges are different than idiot light wire colors. I want to make sure this is correct as well.
ACES #08588
1970 Chevelle SS
post #8 of 21 (permalink) Old Nov 8th, 09, 3:33 PM
robert
the engine bay side wiring is the same. if some of the gauges dont work it will be the pcb as there is no wires that go to each gauge.
post #9 of 21 (permalink) Old Nov 11th, 09, 3:23 PM Thread Starter
Lance
Are the two extra slots grounds, or are they for the amp and temp gauge???
ACES #08588
1970 Chevelle SS
post #10 of 21 (permalink) Old Nov 13th, 09, 9:44 AM
robert
http://www.firstgenmc.com/photopost/...&ppuser=8&sl=a not sure if that works if not here is a straight link http://www.firstgenmc.com/photopost/...&ppuser=8&sl=a . If its the idot light dash the printed board will not have tabs in those spots.
post #11 of 21 (permalink) Old Nov 13th, 09, 10:12 AM Thread Starter
Lance
Thanks Robert.
The car has gauges and not idiot lights.
Very interesting, that the gauge pac wiring connector has no grounds coming in thru it!!!
Do you know how many ground wires come out of the dash harness behind the gauge pac(3???) . Also, of these (3???) ground wires, how many go to the gauge pac cluster metal housing (1 to the clock housing, out side of the PCB)???
ACES #08588
1970 Chevelle SS
post #12 of 21 (permalink) Old Nov 13th, 09, 2:03 PM
robert
I have the one at the headlight switch, there is three grounds that goes to the metal frame work on the dash.
post #13 of 21 (permalink) Old Nov 13th, 09, 3:40 PM
Val
Check out WWW.ClassicCarWiring.com
lt14life is offline
post #14 of 21 (permalink) Old Nov 16th, 09, 10:09 AM Thread Starter
Lance
Originally Posted by lt14life View Post
Thanks Elvis, that was exactly what I was looking for.
Have you bought one before???
ACES #08588
1970 Chevelle SS
post #15 of 21 (permalink) Old Nov 18th, 09, 6:15 AM
We also have Chevelle wiring diagrams in PDF form that you can download on www.peachstatechevelles.com under "Documents" then "Technicial aritcles". Maybe this can help also. The best part,,, it's free!
DanD is offline
