Please Help: New '70 Wiring Harness Dont know where some wires go! - Chevelle Tech
post #1 of 6 (permalink) Old Apr 27th, 08, 8:58 PM Thread Starter
Jack
70 SS Big block, auto, A/C with gauges.
See pics, i am not sure where these wires go.
from right to left:
orange - transmission??
purple and yellow - starter?
The dark blue and black - Not sure
Green Staggered two prong connector- not sure
Black with pink stripe - not sure
Green and blue - not sure
Blue - water temp sender?
Orange and Black- Oil pressure switch??????
ban-ls1 is offline
post #2 of 6 (permalink) Old Apr 27th, 08, 10:20 PM
Re: Please Help: New '70 Wiring Harness Dont know where some wires go!
Elree Colby will have to chime in, I'm definitely half out of it (long weekend)...
from right to left:
orange - transmission? NOT used, should be the HEATER ONLY version power supply lead to blower motor
purple and yellow - starter? PURPLE--provides the power from the key switch, goes to the starter S terminal YELLOW, goes to the R terminal on starter, provides full power to distributor on cranking, other end goes to coil (+) terminal for POINTS ignition.
The dark blue and black - Not sure TCS solenoid mounted on manifold. Mates with the solenoids prongs to provide 12 v power
Green Staggered two prong connector- not sure TCS temperature switch on passenger side of block
Black with pink stripe - not sure TCS relay main power, connects to TCS relay mounted on wire gutter on firewall
Green and blue - not sure TCS relay mates with remaining TCS relay connectors to control power to TCS solenoid.
BY THE WAY TCS = Transmission Controlled Spark. Gives full vacuum to engine depending on block coolant temperature and gear selected on tranmission.
Blue - water temp sender? OIL SENDER
Orange and Black- Oil pressure switch?????? I'm not thinking of it?
Coppertop is offline
post #3 of 6 (permalink) Old Apr 27th, 08, 10:23 PM Thread Starter
Jack
so i dont need the TCS stuff? it is a 69 aluminum intake.
where does the oil sender mount to the engine? I dont have one currently on the car.
ban-ls1 is offline
post #4 of 6 (permalink) Old Apr 27th, 08, 10:24 PM
Mark
Pic #1:
Staggered connector is for the TCS, probably disconnected long ago.
Purple and yellow = starter. May not need yellow depending on HEI/alternator.
Orange is for the blower fan.
Pic #2:
Blue is for your oil pressure light.
Orange and black are for your transmission.
Edit: took me a while to respond I guess, LOL. The oil sender is right by the oil filter.
Mark
1970 SS396
Lewis Racing Engines (Wolfplace) 489:
634 HP @ 6000rpm
627 Lb-ft @ 4,000rpm
ProSystems SV1
Gear Vendors Overdrive
Moser 12 Bolt
Alumitech Radiator
Pypes Exhaust
Dyno
'70 Chevelle
'70 Chevelle 2
Xtreme70SS396 is offline
post #5 of 6 (permalink) Old Apr 27th, 08, 10:46 PM Thread Starter
Jack
thanks guys!!!! I have been trying to figure this out for a few days......
ban-ls1 is offline
post #6 of 6 (permalink) Old Apr 28th, 08, 2:26 PM
70 TCS info
http://www.spgrapevine.com/web/TCS.HTM
Steve Strasemeier (70SS 396, Fathom Blue/White Stripes)
My 70SS
Steve S is offline
