Where does this wire go??? - Chevelle Tech
post #1 of 2 (permalink) Old May 10th, 07, 3:32 PM Thread Starter
70 Chevell - came with factory air which has been removed.
2 part question.
First I have 2 black wires with a purple tracer coming from the bulkhead connector on the firewall. They both run toward the passenger side of the car. One with a single male connector stops around half was accross, the second ends near the right fender. I don't know what they are supposed to connect to. I do see a reference for a TCS relay in the wiring diagram but I'm not sure. What is a TCS relay?
Second. Where does the ground wire from the blower go. The wiring diagram looks like it connects to the A/C relay and to ground. Does it have to go to the A/C relay or can I make a ground wire to go from the blower to ground?
Thanks Guy's
70sschev is offline
post #2 of 2 (permalink) Old May 10th, 07, 3:59 PM
Matt
Re: Where does this wire go???
I can comment on the TCS (transmission control spark)which is a black/purple stripe wire. That wire goes to a relay that (on my 70') is mounted on the gutter above the distributor. I use this wire to power my choke since TCS is usually disconnected (I replaced the 25A fuse for a 5-10A since this ties in with A/C)
Loose wires near starter - what are they?
Harness clamp/holder - above distributor - I need a new 1
Hope this helps.
bochnak is offline
