VDO pro eliminator tach Not working!!!! - Chevelle Tech
post #1 of 2 (permalink) Old May 1st, 07, 8:16 AM Thread Starter
I have a pro eliminator tach that was working perfect 2 days ago. I installed new msd spark plug wires, accel cap and rotor (hei) and hooked everything back up the same way. Fired the car and the tach was jumping around, shift light flashing. Shut down checked wiring everything tight. Started car tach did same thing. Then the tach needle shot to 9000 rpm and just stop working all together. Now it does not work at all except for the recall buttons. Does anyone have an idea what the problem might be?????
Barry
barrym69 is offline
post #2 of 2 (permalink) Old May 1st, 07, 3:14 PM
Greg
Re: VDO pro eliminator tach Not working!!!!
I would check everything again. What does your ignition system consists of? HEI with power and tach terminals? Sounds like power was being applied to the tach sender wire. Check and make sure power and tach wires and terminals are insulated from each other.
Greg U
MY 70SS
undee70ss is offline
George Costanza's Rules for Working Derek69SS Bench Racing 7 Sep 30th, 05 6:25 PM
Dash lights aren't working. SS_Sean Electrical & Wiring 7 Sep 6th, 05 9:51 AM
cd, dvd drives not working properly no1dc Bug Hunt 2 Mar 14th, 05 4:25 PM
Interior Lights Stopped Working. (Chevy Van) garfield Electrical & Wiring 9 Mar 6th, 05 3:07 PM
Front disc brakes not working on 1971 Chevelle Bandit1978 Brakes, Suspension & Steering 7 Nov 9th, 04 8:08 PM
