New Headlight wiring harness for a 1971 Chevelle - Chevelle Tech
post #1 of 4 (permalink) Old Apr 29th, 07, 10:00 AM Thread Starter
Which vender has a good one to replace a old original..that is corroded..is it a hard replacement?
1971 CHevelle Malibu 350 auto no AC
Bandit1978 is offline
post #2 of 4 (permalink) Old Apr 29th, 07, 11:16 AM
George
Re: New Headlight wiring harness for a 1971 Chevelle
American Auto Wire or M&H make a simple plug and play type wiring harness. I'm about to do this on my '69. I've already rewired everything from the trunk to the firewall. Get the one specific for your car and start the swap. You'll need new fender plastic clips (old ones will break) but that's not a big deal and Ground up has them.
Speed Shop is offline
post #3 of 4 (permalink) Old Apr 30th, 07, 9:06 PM
Ron
I have and now am installing new harness from M&H - front to tail. It's truly Plug-n-play. I love it. All prepackaged, exact same factory colors and plug ends. Just lay the new segment next to the old where you can and unplug and replaug as you go. It helps (me anyway) that I have color coded wiring diagram from John Anastasio - nice, encased in hard plastic twenty bucks or so. Go to www.classicCarWiring.com. I refer to it a few times. LAst, The Factory assembly manual answers any-n-all final questions like routing, body clips etc.
Sparty
'69 SS 4 speed
Go to: www.Green396.blogspot.com
Ron H is offline
post #4 of 4 (permalink) Old May 1st, 07, 7:22 AM
Greg
Originally Posted by Shannon Custalow View Post
New Headlight wiring harness for a 1971 Chevelle...........Which vender has a good one to replace a old original..that is corroded..is it a hard replacement?
There really is no headlight harness. Headlights are in the FWD lamp harness. What is wrong with yours? If its just the connectors for the headlights, you can buy just the plastic bodys and terminals.
Greg U
MY 70SS
undee70ss is offline
Headlight harness routing 72 Chevelle JayJ Electrical & Wiring 0 May 9th, 06 9:08 PM
70 chevelle wiring question again HopkinsChevelle Electrical & Wiring 9 Apr 27th, 06 9:11 PM
Need Help With Correct Part Number For 1967 Ss 396/375 Holley Carb--- mrh51072 Restoration Corner 5 Apr 27th, 06 1:09 AM
67 chevelle wagon wiring harness lov2rev Chevelle Tech 1 Apr 23rd, 06 5:25 PM
Installing Wiring Harness shaddow Electrical & Wiring 0 Sep 4th, 05 6:56 PM
