1970 Fan blower switch - Chevelle Tech
post #1 of 10 (permalink) Old May 17th, 06, 11:32 PM Thread Starter
I've got a '70 Chevelle project car and when I bought it the fan did not work at all.I'm just about finished and going thru everything for inspection so I'm trying to get the fan to run.By process of elimination,I've run a hot wire to the fan and it works.I've got juice up to the fan switch.If I jump a wire to the other side of the plug in at the fan switch it will run on high only.This was a AC car so I know it has to have everything that it came with (resistors,relays,etc.which I don't have)for it to run on low and medium,but I would be perfectly happy to have high and off.My question is if I replace the switch,it should do this right?And where can I find a switch since Autozone,Napa,Advance,nobody has a listing for one.Thanks.
BUDS1970 is offline
post #2 of 10 (permalink) Old May 18th, 06, 12:08 AM
Send a message via AIM to JayJ
Re: 1970 Fan blower switch
Buds1970, please keep us posted on this situation. I am trying to convert my A/C to heat only using the factory A/C controls and "non-air" blower resistor. I picked up the resistor for 9 bucks from my local classic Chevy store/shop.
However, I have not found much information on the wiring now that I have the resistor.
I have heard I should be able to get rid of the entire A/C harness inside the engine compartment and have a single wire running to the blower from the resistor?switch?
Let us know!
JayJ is offline
post #3 of 10 (permalink) Old May 18th, 06, 10:00 PM
Have you tried True Connections?
http://www.true-connections.com/
post #4 of 10 (permalink) Old May 19th, 06, 2:04 AM
Dean,
Any info on how to wire an air conditioned vehicle blower speed switch to a non-air resistor then to the blower motor so I get more than one speed?
JayJ is offline
post #5 of 10 (permalink) Old May 19th, 06, 10:57 AM
I think you're going to need to put the original resister back into the air flow.
I'm sure there are other ways to make the motor operate a different speeds but probably more trouble than it's worth.
post #6 of 10 (permalink) Old May 19th, 06, 4:09 PM
Jay
I had no idea this was so complicated. I guess that explains why the 70 I just bought is missing the blower switch. It was an A/C car, but the compressor was taken out of it.
There's a switch on ebay. I considered buying it, but now I apparently have more to learn about the system first.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Jay
jat70 is offline
post #7 of 10 (permalink) Old May 19th, 06, 5:19 PM
DG
DG, my initials
Send a message via Yahoo to DG
The switch is working if you get off, HIGH fan speed and nothing. The HIGH does not go thru the resistor pack. It connects the 12v right to the fan. You should be able to duplicate that. I know I can wiggle my switch and loose med and low speed. HIGH is alway there.
I got my switch from GM a couple years ago. I think the NOS parts are goen. Repops are available.
A used switch would be ok.
70 Malibu
TEAM Chevelle Member #0086
Used to be a member of Tri-State Chevelle
http://www.chevelles.net/tristate/
DG is offline
post #8 of 10 (permalink) Old May 19th, 06, 9:29 PM
Doug
For high speed, the switch operates a relay under the hood on the firewall that connects a 12V power supply to the blower motor.
Doug
TC#2270
ACES#6402
Chevelle Club of Michigan
my chevelle
stroobydoo is offline
post #9 of 10 (permalink) Old May 19th, 06, 9:48 PM
It obviously works if jumpering/bypassing the bad switch make the motor run on high speed.
post #10 of 10 (permalink) Old May 21st, 06, 6:56 PM Thread Starter
I wired a toggle switch in between the brown hot wire and the orange wire going to the fan.I'm perfectly happy with off and high.I even mounted it in the same location as the original switch so it looks somewhat authentic.
BUDS1970 is offline
69 Chevelle heater fan switch h2750 Electrical & Wiring 22 Sep 17th, 06 10:56 AM
1970 Fan shroud bbjhill Heating & Cooling 0 Sep 26th, 05 10:39 AM
1970 chevelle power trunk release glovebox switch s5757s Restoration Corner 1 Apr 14th, 05 9:49 PM
1970 AC/heater/blower motor question, any experts? Narti Heating & Cooling 4 May 14th, 03 6:25 PM
Resistor bridge for blower switch - '70 AC? mahlmann Electrical & Wiring 1 Feb 27th, 02 2:52 PM
