5 terminal relay vs 4 terminal ??? - Chevelle Tech
post #1 of 2 (permalink) Old Sep 27th, 05, 9:05 AM Thread Starter
Pete
I know by now you all are getting tired of my questions but I don't know the answers, obviously, and was hoping you would tolerate this electrically challenged persons questions once more.
I've read and done a search on relay's to brighten the headlights. Thought I had it figured out Alt/Bat power to term# 30, Switched power to term# 86, line out to headlights term# 87 and term# 85 to ground. Pull out the relays I purchased a while back(couple of years at least) and they have 5 terminals the above mentioned and the additional term# 87a.
Color code are as follows;
Term# 85 white(ground)
Term# 86 red(line from light switch, lt grn brights, tan lows)
Term# 87 green(line out to headlights lt grn brights, tan lows)
Term# 87a blue ???
Term# 30 black[power in from either alt or bat(jct block)]
The relays are Beuler 12V 40/50A BU-5083-0000
TIA Pete and Nicholas
Any help would be greatly appreciated.
Member# 1097
1970 Chevelle 350cu w/ th350, 750 edel carb, perform intake and lopey cam of unknown specs which produces low vacuum 7-9", otherwise stock motor.
67 std Camaro conv, 1978 Corvette, 03 Silverado, 13 Sonata Hybrid
http://s62.photobucket.com/albums/h8...t=DSC01103.jpg
no1dc is offline
post #2 of 2 (permalink) Old Sep 27th, 05, 12:23 PM
Hank
Re: 5 terminal relay vs 4 terminal ???
You've got it right, just don't use 87a. 87 is a normally open contact, no power out until you energize the relay. 87a is a normally closed contact, power out until you energize the relay. 87a is just the opposite of 87.
Hank
My Chevelle
Finally is offline
Quick Q on CS130 conversion Pt.4 !!!!! :) feedphillipnow Electrical & Wiring 10 Jun 25th, 03 11:24 PM
Calling John Muha...Alternators oman Electrical & Wiring 15 Jun 21st, 03 1:38 AM
searched,no luck - what is the benefit, if any, for serpentine belts? Bill_L Heating & Cooling 25 Feb 11th, 03 12:13 PM
Another CS130 Alternator Question 72SSAbody Electrical & Wiring 4 Dec 2nd, 02 2:18 PM
