I am trying to find a wiring diagram for my '70 SS dash with gauges???
This wiring diagram is not in my '70 GM service manual, '70 GM assembly manual, '70 Fisher body manual or in my Chiltons manual. Only idiot light dash wiring diagrams are shown in all of these???
Please help, as I am getting ready for the big "DASH PULL" this winter, to get all dash componets working again as they should.
It's fairly easy since there is a 12 pin plug which plugs into the dash and then the pcb takes care of the rest for the dash, all of the dash lights are the same bulbs.
I have a wiring book for a 70 Chevelle with the idot lights and SS center section. I've looked at both and its basiclly the same thing other then the SS dash having all 12 slots filled in the plug.
Thanks Robert, but I was hoping that someone would make a more detailed wiring diagram for '70 SS dash with gauges.
There is alot of rigging behind my dash and many of my gauges don't work. I am trying to make sure that every thing is right before I install my newly rebuilt gauges.
Also the wiring colors for the "forward lamp" harness with gauges are different than idiot light wire colors. I want to make sure this is correct as well.
Very interesting, that the gauge pac wiring connector has no grounds coming in thru it!!!
Do you know how many ground wires come out of the dash harness behind the gauge pac(3???) . Also, of these (3???) ground wires, how many go to the gauge pac cluster metal housing (1 to the clock housing, out side of the PCB)???
We also have Chevelle wiring diagrams in PDF form that you can download on www.peachstatechevelles.com under "Documents" then "Technicial aritcles". Maybe this can help also. The best part,,, it's free!
Thanks Stan:beers:, but that one is also for '70 SS round gauge dash with idiot lights. You can tell, as the printed circut board connector for the gauges has two missing wires from the black plastic connector.
On '70 SS dash with gauges, all of the "ports" on the black plastic connector for the printed circut board are fully filled up (no empty holes).
I am starting to think that GM never published a wiring diagram for these dashes with working gauges. All of my info is for SS dashes with idiot lights.
I know this is an older thread but thought I would add this. I just bought a 70 /71 wiring diagram(s) in colour from www.classiccarwiring.com. Nice piece; laminated correct colour codes and even got, power windows, seats, A/C wiring diagrams. AND it has the gauges!!!!!
Levon, thank you for posting this source. I never did find a wiring diagram for '70 dash, engine harness, and forward light harness with dash gauges. I can not beleive that this information was so hard to find for such a popular car.
I believe that the wiring diagrams are correct for the SS dash gauges; it's just that the "wiring" diagram does not include the printed circuit information due to the fact it is not wiring. You would need to look at the connecting plug pin information at that point to have the complete wiring system.
Related Threads
Team Chevelle
5.1M posts
115.6K members
Since 1998
