Kick Panels with Speakers and Vintage Air - Chevelle Tech
post #1 of 12 (permalink) Old Dec 28th, 12, 7:44 AM Thread Starter
Rich
Does anyone know where I can get a set or just the passenger side kick panel with a speaker to allow me to use the Vintage Air pass thru for the hoses. The ones I see for sale such as the KCHV-64/6 from Custom Auto Sound are molded without the factory vent.
If any fabricators offer them or if someone on here has dealt with this issue I would greatly appreciate your input.
Thanks in Advance!
Rich
Rich1966 is offline
post #2 of 12 (permalink) Old Dec 28th, 12, 8:30 AM
Re: Kick Panels with Speakers and Vintage Air
Hey Rich, I may be misunderstanding you, but the kicks from Custom Auto Sound that I have on my 64 do have slits in them behind the speakers so the factory vents still work. In my 64 the vent is a separate piece behind the kick panel cover so the flap opens and closes behind the kick panel and the slits allow the air to still come through. I did however have to remove the parking brake on the driver side to be able to use them.
So many projects, so little time!!!!!
1964 Malibu 4 dr wagon 327 auto
1965 Malibu 2 dr hardtop 427 auto
1965 Chevelle 300 Deluxe 2 dr post 427 4 spd project
1967 Buick Special 2 dr hardtop project
1968 Camaro LS1 6 spd project
1998 Pontiac Trans Am WS6 LS1 6 spd driver
ACES Member #2099
Heartland Chevelle Club Member
www.klassickeyless.com
tpelchat is offline
post #3 of 12 (permalink) Old Dec 28th, 12, 8:45 AM Thread Starter
Rich
Yes, they do have a vent but its molded different than the original panel. Installing the vintage air system requires you to use that original style kick panel with the oval vent in it. I need a kick panel molded just like the original but with a speaker molded into it.
Rich1966 is offline
post #4 of 12 (permalink) Old Dec 28th, 12, 10:21 AM
Kevin
I have seen the panels with a speaker in them for a factory air car that have the pass through. Some of the non-AC kick panels use the factory vent hole for the speaker which won't work with the VA system. The non air car systems requires you to cut up the original kick panels which is something I didn't want to do. My car is non-air and I ordered the AC kick panels which should work with some minor fab work.
"If your not living on the edge, you're taking up too much space" - Jim Whittaker
AFR Eliminator 195's
FAST EZ EFI
SC&C Stage II Plus suspension
Hotchkis/Hellwig sway bars
Tremec TKO 600
Chevy67 is offline
post #5 of 12 (permalink) Old Dec 28th, 12, 3:27 PM
Bryan
I have VA in my 66
A Gen IV unit that utilizes the vent opening for the hoses---so the vent is gone.
since that vent is gone---I went ahead and removed the driver vent as well
(Never did use them anyway)
Used the CAS kick panels for cars with AC and some very shallow pioneer speakers.
Did not remove the parking brake---but I did have to modify it for speaker clearance.
A couple of cuts with a die grinder and a bit of welding and the parking brake is fine now.
Bryan's toyz
66 ElCamino 3oh7/TKO 5spd (mousey) Almost done On the street now!!!
Bryan59EC is offline
post #6 of 12 (permalink) Old Dec 28th, 12, 4:01 PM
Richard
I have the CAS kick panels for 66 with AC in mine. Just converted from factory air to the gen IV this last summer, they worked good. Just some minor trimming for the new evaporator unit.
Richard
66 Malibu
ramprodent is offline
post #7 of 12 (permalink) Old Dec 28th, 12, 4:06 PM
Richard
Bryan, any pics of the e brake pedal? I just restricted upward travel on mine. Thought about relocating somehow but took easy way out.
Richard
66 Malibu
post #8 of 12 (permalink) Old Dec 28th, 12, 9:35 PM Thread Starter
Rich
Can some one please post a picture with those kick panels installed. I would really appreciate it.
RIch
Rich1966 is offline
post #9 of 12 (permalink) Old Dec 29th, 12, 1:32 AM
Bryan
Rich & Richard----I will try to get them Saturday sometime
Bryan's toyz
post #10 of 12 (permalink) Old Dec 29th, 12, 12:14 PM
Bryan
Kick panels.
Cannot recall where I got these, but they are probably Custom Auto Sound.
Speakers are Pioneer --- shallow mount --- cannot find these same speakers where I bought them.
http://www.sonicelectronix.com/viewc...rch_id=1279477
These are the options as you need a shallow speaker.
The kick panels in the car.
these are for AC applications and a bit of trimming was required on the passenger side
for hose clearance-----not visible at all.
Parking brake.
Bryan's toyz
post #11 of 12 (permalink) Old Dec 29th, 12, 2:31 PM Thread Starter
Rich
Bryan,
Thank you very much, well that answers the question. I was not visualizing it when I saw the ad for them on CAS's web site, but now I see how the will fit with the VA system. Thanks man for all your help and info!
Regards,
Rich
Rich1966 is offline
post #12 of 12 (permalink) Old Dec 31st, 12, 3:14 PM
Richard
Thank you as well Bryan.
Richard
66 Malibu
This Thread is more than 1577 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
