dimmer switch replacement on 85 k5 blazer - Chevelle Tech
post #1 of 5 (permalink) Old Nov 21st, 09, 8:04 PM Thread Starter
Ronnie
if anyone has done this could you give me some tips on replacing this or if you have a schematic that you could send would be greatly appreciated and sorry if in wrong forum
70 Elky 350 /th400== gone traded it for 70 fastback mustang project car
53 Chevy truck 6cyl/th350
57 Belair 350/4sd
68 Mustang originally bought new by my wifes grandfather 6cyl/3sd
72 Chevelle SS 454 th400 have matching vin #s 402 safely stored in the garage.
72SSdummy is offline
post #2 of 5 (permalink) Old Nov 21st, 09, 9:28 PM
Re: dimmer switch replacement on 85 k5 blazer
85 is dir lever actuated, not floor mount, correct? If so, pretty easy, drop the dash filler under the column, then loosen the 2 mounting bolts that hold the column up against bottom of the dash. The dimmer switch is on top of the column, piggy backed on top of the ign switch, and actuated by a steel rod. If you work the dimmer switch lever with one hand while feeling on top of the column with the other, you should feel the rod moving. Follow the rod down the column and it will take you to the dimmer switch. Held on by 2 small bolts, you might luck out and just need to adjust it by loosening the bolts and sliding it up or down as required. Good luck, Jim.
72 Chevelle SS conv http://www.fquick.com/454ragtop
72ragtop is offline
post #3 of 5 (permalink) Old Nov 21st, 09, 10:13 PM Thread Starter
Ronnie
Thanks Jim we will give it a try
57 Belair 350/4sd
post #4 of 5 (permalink) Old Nov 21st, 09, 10:40 PM
It is the switch on the right.
it is not whether you win or lose but how you place the blame
64 Nova 400 series
Philip is offline
post #5 of 5 (permalink) Old Nov 21st, 09, 11:47 PM
Banned
Anthony
The only help I can offer is www.67-72chevytrucks.com. Go to the 73-87 page. Those guys know these year trucks like we know chevelles. Good forum, one of my favorites next to this one.
sschevellefan is offline
This Thread is more than 2744 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
