66 or 67 Dash Photos - Page 2 - Chevelle Tech
post #16 of 22 (permalink) Old Feb 23rd, 12, 12:43 AM
Elroy
Re: 66 or 67 Dash Photos
I agree DaleM on the shiftworks kit. i did that one in the camino and same will go in the SS. I just do not like round guages in a 66-7 as the dash does not have those lines at all. Has to be a sweep speedo for me....
66138 is offline
post #17 of 22 (permalink) Old Feb 23rd, 12, 2:05 AM
David
Originally Posted by Chris R View Post
David, if you scroll up to Dales post #6. That should help answer your question. If your asking if 66 gauges will fit a 67 or vise versa. I do believe they will swap. Although ill admit I havent personally seen both year gauge clusters side by side to see if they would match. Ill bet Dale can answer that one too.
I'll be unable to do a side by dide of the two gauges cliusters, being they are a state away. I'm gonna start a new posts since the title of this one isn't related to the question and it being two years old. thanxs david New post here: http://www.chevelles.com/forums/show...62#post3439662
55 210 Chevrolet New project
64 El Camino (sold to finance new project)
67 SS Chevelle '396
69 Sanger Flat Bottom boat
77 El Camino parked daily driver
78 Z/28 Camaro, High School Car Class of 80 350'
80 Spectra 21' Mini Day cruiser Blown 454
88 IROC Camaro (sold to finance new project)
1994 fac2 dr Blazer 4x4
02 F-250 7.3L Diesel 4" lift
david_396 is offline
post #18 of 22 (permalink) Old Jan 26th, 17, 2:13 AM
Dang, that's it? I guess I've been doing some digging into the aftermarket gauge clusters as I'm trying to turbo my LS motor if I can. Hoping that there are more options and I do like the Dakota gauges but I am leaning towards something more custom and digital. I just want something that doesn't look cheap and doesn't look ****ty. Guess beauty is in the eye of the beholder anyways lol
I guess if anybody has any other pics of their gauge clusters please post them here...
2005 G35 Coupe FULLY Rebuilt, stroked/sleeved 4.15L VQ35de w/ GReddy Twin Turbo setup...pushed 650 RWHP and 680 FTLBSTQ
Currently 1967 Chevy Malibu with a destroyed 383 stroker motor...undergoing surgery with an LQ4 donor ( http://ls1tech.com/forums/conversion...l#post19424975 )
crmd37 is offline
post #19 of 22 (permalink) Old Jan 26th, 17, 2:58 AM
David
http://www.cardomain.com/ride/307290...rolet-chevelle
davewho1 is online now
post #20 of 22 (permalink) Old Jan 26th, 17, 3:36 AM
Rich
Nothing too drastic here...
HandOverFist is offline
post #21 of 22 (permalink) Old Jan 26th, 17, 4:06 AM
Rod
here's what I'm working on for my '66. I didn't want to mount mine on top of the dash so I made my own 'pod' that bolts to the bezel just like the factory cluster. Then I took some plexi and with my heat gun I contoured it to fit the bezel. In the final version, which I still have to cut, will have the blinker lights, high beam light, check engine light, and gear indicator cut in it as well. I am still looking at what, if any, other icons that I may include as well because my EFI system has the ability to provide various warnings that I could create icons for and include them as well. The gauges are back lit LED and look pretty cool at night...
1966 Malibu, 540 BBC FAST XFI EFI, 4L80E Trans, 2800 Stall, Quick Performance 59" 9" Ford Rear End w/3.50 gear
66 Bu is offline
post #22 of 22 (permalink) Old Jan 26th, 17, 4:13 AM
Probably not what you're looking for, but I swapped a '67 gauge dash in my '66 Elkie instead of the 'idiot light' setup. Then I put in a T-5 trans, so the speedo cable didn't work. This was back in the day before the internet and multiple catalog stores.
When I needed more gauges, and ones that actually worked, I put in a Camaro console and gauge pod with room for 4 more. Currently running a tach and GPS speedo from Speedhut, cheapo oil and S-W vacuum gauges in it.
The console addition also allowed a place for a few rocker switches aft of the shifter for add on stuff like under dash lights and for the back up lights (since the tranny didn't work for them either).
1966 El Camino
Custom painters don't screw up! They just add more graphics.
Moderator - nevadashooters.com
Tophog is online now
