Console ABS plastic repair? - Chevelle Tech
post #1 of 8 (permalink) Old May 28th, 08, 8:36 AM Thread Starter
Hey everybody:
Since I'm cheap, I'm gonna try to repair my original ABS plastic console base instead of buying a repro. I don't know how good the repros are, and for $200 I'd rather try to refurb mine. It has a crack in the side and a rather sizable hole in the bottom of the compartment.
Has anyone repaired holes/cracks in their base; if so what did you use and how well did it work?
I'm thinking about trying this stuff, it sounds promising:
http://www.urethanesupply.com/mm5/me...Category_Code=
Thanks for any advice!
Here's a pic of the hole:
Name:	Console hole  5-7-08  6.jpg
David
http://www.cardomain.com/ride/307290...rolet-chevelle
davewho1 is online now
post #2 of 8 (permalink) Old May 28th, 08, 10:03 AM
Wayne
Re: Console ABS plastic repair?
I used JB Weld on my 66 console to fix holes like that, but this stuff looks promising. Since it does not stick to polyethylene, you could just press a plastic zip lock bag against the bottom side of that hole, then pour the liquid repair material from the top to fill in the hole. I would run some tests to see (1) how well it sticks to the console plastic in inconspicuous places, and (2) to determine the optimum mixture of the 2 parts. Good idea on fixing your console, prices for them anywhere are insane.
66 Chevelle SuperSport 396/325 4-speed
Before Restoration
Now
wayner66 is offline
post #3 of 8 (permalink) Old May 28th, 08, 11:55 PM
Send a message via Yahoo to wambams69ss396
Originally Posted by davewho1 View Post
Hey everybody:
Sounds like the stuff i found at eastwoods website.i was going to use if for repairing my plastic inner fender wells on my 69.
heres the link
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
wambams69ss396
69ss396 chevelle HT
57E fathom green
bench seat w/dark green interior
396 325hp
3.73 posi
http://i492.photobucket.com/albums/r...pszhp1iwhw.jpg
69SS396 chevelle convertible
71A lemans blue
bench seat w/parchment interior
http://photobucket.com/69chevelleconvertible
TC#3512
Billy M
wambams69ss396 is offline
post #4 of 8 (permalink) Old May 29th, 08, 7:46 AM Thread Starter
I guess nobody else is gonna chime in ... I'll order some of that stuff and try it out. I'll update this thread with results.
David
post #5 of 8 (permalink) Old Jun 1st, 08, 4:02 PM
I have to repair my threads in the platic on the top of my 71 console. The top plate screw holes are completely stripped. Is there anything i can do to fix it? I've never heard of re-threading a hole in plastic before. Any ideas or help would be great. thanks
71 Chevelle SS
383-TKO600
bdc1013 is offline
post #6 of 8 (permalink) Old Jun 1st, 08, 4:11 PM
Fill hole with epoxy, re-drill and re-tap.
post #7 of 8 (permalink) Old Jun 1st, 08, 7:18 PM
Mark
Deans Idea of epoxy drilling & tapping works well
on plastic repair visit the motorcycle shop they have Fairing repair glue & filler that is simply Great !!!
on the better kits you even can get a molding bar ..... press it into the pattern on the part
then cover the hole & the filler will dry an come out with the proper texture to match the original part your repairing
"An expert is someone who has made every possible mistake within a very narrow field"
68KMENO is offline
post #8 of 8 (permalink) Old Jun 2nd, 08, 5:02 AM
I seem to remember the holes go straight through. If they do, i could just put duct tape on the bottom, fill with the epoxy (can i use JB Weld?) wait for it to dry then i drill it out and put threads in it just like in metal?
71 Chevelle SS
383-TKO600
bdc1013 is offline
