Chevelle Footwell LED Kit! RGB Multicolor and Single Color Options! - Chevelle Tech
post #1 of 78 (permalink) Old Sep 3rd, 14, 1:08 PM Thread Starter
Nick C.
Lightbulb Chevelle Footwell LED Kit! RGB Multicolor and Single Color Options!
Looking to add a modern look to your Chevelle's interior? Footwell LEDs are the way to do it! By adding bright LED strips under your dash, you can add a lot to the look of your Chevelle.
Diode Dynamics has been producing and designing easy-to-install LED kits for nearly a decade, and this kit is no exception. After months of planning, we have designed new LED strips to be used in this kit, which are highly flexible, waterproof, and long-lasting. This kit also uses our brand new RGB Multicolor products, which are controlled by the included remote! You can change the color to fit your mood.
Customer Submitted Photos:
Included in the kit:
  • 2 (two) 30-5050 SMD Strips (flexible and IP67 waterproof)
  • Wiring harness for easy installation
  • 2 (two) quick-splices for installation
  • LED Toggle switch in your choice of LED color
  • RGB Controller Box with RF sensor and 4 outputs
  • Remote Control (choose Standard or upgrade to Bluetooth or WiFi)
  • 4 (four) zip-ties and 3M outdoor adhesive pads for mounting strips
  • 3-year Diode Dynamics worry-free limited warranty
  • 30-day satisfaction guarantee
Also included with Rear Footwell option:
  • 2 (two) additional 30-5050 SMD Strips (flexible and waterproof)
  • 2 (two) 3-meter (ten-foot) extension wires
  • Additional zip-ties and adhesive pads
Any questions email us at contact@diodedynamics.com or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks!
Nick C.
Diode Dynamics is offline
post #2 of 78 (permalink) Old Oct 10th, 14, 2:14 AM
Big Mook
Re: FS: Footwell LED Kit! RGB Multicolor and Single color options!
How much
blonby1970 is offline
post #3 of 78 (permalink) Old Oct 10th, 14, 9:43 AM Thread Starter
Nick C.
Originally Posted by blonby1970 View Post
How much
Single color kits start at $30, Multicolor starts at $40
U.S. forum members send us a PM for the free-shipping code
Nick C.
post #4 of 78 (permalink) Old Oct 13th, 14, 9:19 PM
JKK
JK
Do you have to use the remote with a single color (white) just want it to come on when the door is opened?
67 El Camino ZZ 383 > FI-Tech F.I. / 700R4 /12 Bolt Posi 3.73s / P/S P/B A/C
" Rancheros the Other Short Bus"
JKK is offline
post #5 of 78 (permalink) Old Oct 14th, 14, 9:33 AM Thread Starter
Nick C.
You can wire it up to come on when the door is open. The light will stay on the last color you selected so if you wanted to leave it white, you could
Nick C.
post #6 of 78 (permalink) Old Feb 25th, 15, 12:51 PM
Location: Aloha Oregon, a rainy but very green Portland suburb
Nice price! I make electric signs and channel letters and I am very familiar with LED's. I started illuminating my signs with LED's 2 years ago. Lightweight, no heat and 12 volt. So much better than using neon as I did before. 15,000 volts, glass that breaks and 30 pound transformers. No chance of fire or shorting out and going to ground. Waterproof even.
My "Time Machine", sold and gone. Looking for another.
http://i133.photobucket.com/albums/q...psg6h1b8ii.jpg
YankeeRodder is offline
post #7 of 78 (permalink) Old Feb 25th, 15, 3:01 PM Thread Starter
Nick C.
Yep! They are definitely safer and more efficient than the old neon-tube days
The strips in this kit are IP67-rated and provide plenty of light for these applications
Nick C.
post #8 of 78 (permalink) Old May 5th, 15, 10:57 AM Thread Starter
Nick C.
Nick C.
post #9 of 78 (permalink) Old May 20th, 15, 10:36 AM Thread Starter
Nick C.
Looking to add a unique touch to your engine bay?
Thanks!
Nick C.
post #10 of 78 (permalink) Old Jul 14th, 15, 10:16 PM
Re: Chevelle Footwell LED Kit! RGB Multicolor and Single Color Options
That's nothing new. Back in the 80's I added red marker lights under the dash of my 77 Camaro R.S. Worked off a toggle switch. Also painted the inside of the dome light lense red. On a hot date there were mood lights.
Chevycollecter is offline
post #11 of 78 (permalink) Old Jul 21st, 15, 11:08 AM Thread Starter
Nick C.
LEDs have come a long way since the 80's! But the basic concept is the same
Nice work with the mood lights
Nick C.
post #12 of 78 (permalink) Old Sep 12th, 15, 7:48 AM
JOHN
I just installed L.E.D. turn signals in my 72 Chevy truck front and rear ,with only the rear lights in they flash as they should ,when I installed the front ones none flash.Do you sell a non load flasher that will make them work ? I dont know who the manufacturer of the lights are as I bought them from an individual .If you have something a price and ordering info would be great.
FLASHED is offline
post #13 of 78 (permalink) Old Sep 14th, 15, 11:09 AM Thread Starter
Nick C.
John,
Your LEDs should be flashing (albeit it faster than normal) even without resistors or a replacement relay module.
I suggest checking the metal contacts in the socket, and adjusting the bulb to make sure it's securely installed. If it's not making firm contact with the tabs in the socket, it's not going to function correctly.
Nick C.
post #14 of 78 (permalink) Old Apr 7th, 16, 7:52 PM
Stu
The descriptions say strips but the video shows bulbs, what if we want the bulbs and not the strips?
chuckd71 is online now
post #15 of 78 (permalink) Old Apr 8th, 16, 8:50 AM Thread Starter
Nick C.
We have RGB LED bulbs available in many of the larger low/high beam sizes, but we don't offer an RGB interior bulb at the moment.
The strips are an easy solution to provide accent lighting
Nick C.
