fuel tank leak - POR, rad shop or new? - Chevelle Tech
2003 General Tech Forum from 2003
post #1 of 10 (permalink) Old Jul 14th, 03, 7:26 AM Thread Starter
Post
I pulled the fuel tank yesterday because of a drip drip drip. Seems to be coming from the front seam near where the passenger strap crosses.
I got a rough quote from a radiator shop to look at it and fix it for $60 (I did not know at the time it was leaking near the seam).
Based on searches here - it seems like POR is preffered to the system from Eastwood. $30 plus S&H.
New tanks go for about $170 plus S&H.
Any opinions? TIA
Growing old is mandatory; growing up is optional
67 Malibu Convertible
http://www.frappr.com/teamchevelle/photo/229208
K_Janisch is offline
post #2 of 10 (permalink) Old Jul 14th, 03, 7:55 AM
Post
Not sure about a seam but I've patched 'em up with cheap ol JB Weld already. (for pin holes)
Bob (Pa.)
http://www.348-409.com
My Toys:
1963 Impala 283/PG 3.36
1966 Impala 327/PG 3.36
1966 Chevelle SS 409/M22 3.55
1969 Chevelle 307/PG 3.08
1969 C10 stepside 454/TH350 3.73
1969 Custom 30 wrecker 350/4 spd 4.10
1971 C20 pickup 305/4 spd 4.10
1971 Chevelle 6/PG 3.08 4 dr
1972 Chevelle 454/M21Y 4.10
mr409 is offline
post #3 of 10 (permalink) Old Jul 14th, 03, 7:57 AM
Post
Nothing wrong with having a radiator shop boil out & solder repair the leak. A new tank is not really necessary unless you have it boiled out & chunks of the skin of the tank are coming apart, then replace it. If the tank needs to be replaced, your radiator shop will advise you of the need. I am not sure why you mentioned POR15, is it capable of sealing a gas tank leak? If that is why you mentioned it, I think you are putting your life in extreme danger, when it comes to a fuel leak OF ANY KIND in a gas tank, have it repaired professionally.
It is EXTREMELY dangerous especially if you drain the tank yourself, drop it & try soldering it yourself, YOUR TANK IS FULL OF FUMES!
You may also want to consider replacing your gas gauge sending unit, there only a couple of bucks, if you drop your tank, now is the time to do it.
[img]graemlins/waving.gif[/img]
A.C.E.S. 4996
Frame off red 71 Chevelle SS496 Convertible with white stripes, top & interior loaded with factory options: TH400, cowl induction, power windows, locks, cruise, tilt, top, trunk, 12 bolt 373 posi, A/C, AM-FM 8 track, power drivers bucket seat, mirror map light, trunk, hood, glove box lights, on the wheel GM air pressure gauges, Delco Jac Pac 175 (under hood vacuum powered air compressor) with under dash Delco air pressure controller/regulator, complete with Jac Pac 175 air shocks.
http://chevelle.ogleonline.com/jim.htm
1952 Chevrolet 4 door Deluxe Sedan with a 216.5ci in line 6 with the last RAJO (RAcing JOe) Power Cylinder Head designed by grandfather in the 1940's. Joe designed, built & sold all over the world performance heads during the 20's, 30's & 40's starting with the model T Ford. Joe drove in the FIRST INDY 500 in 1911 as car # 8.
Watch for my SS496 Chevelle as a pace car at Indy in 2011 (100 years after Grandpa Joe) IF THEY WILL LET ME !
71BBSSCONV is offline
post #4 of 10 (permalink) Old Jul 14th, 03, 12:22 PM
Post
Here's still another opinion...Unless you are positive that the leak is at the seam and that there isn't scale rust inside the tank, spend the extra bucks and buy the new tank. It is highly likely that there will be budding rust issues inside a 30+ year old tank.
The $30. for the POR tank sealer is a bit deceptive. You also need the Marine Clean and Metal Prep POR products to properly prepare the inside of the tank before you pour in the sealer. To do it right with the POR products, the actual cost will be closer to $55-$60. That doesn't count the couple of hours time to clean/flush/clean/flush, etc.
If you intend to keep the car for a long time, spend the money for a new tank and sending unit. You'll sleep better.
vettefella is offline
post #5 of 10 (permalink) Old Jul 14th, 03, 12:28 PM
Post
I am leaning twoard agrreing with vettefella, yes it may end up being somewhat cheaper to have your radiator shop fix the leak, but why did it start leaking now. It may be due to some hiden rusting problem, and after you get this leak fixed you will probably get another one sometime down the road. When it comes to something as important to your safety as the gas tank, I would just spring for a new one.
Mat Ellison
70 SS 396 Chevelle (Sold)
62 Impala Sport Coupe (Thinking of Selling)
2001 Grand Prix GT (Sold)
Aces #2424 (Lapsed)
Team Chevelle #1998 (Lapsed)
Heartland Chevelle Club member (Lapsed)
Chevelle Page
www.angelfire.com/amiga/elliboom
"Knowledge is Good"
ELLI is offline
post #6 of 10 (permalink) Old Jul 14th, 03, 1:02 PM Thread Starter
Post
thanks for the replies.
71BBSSCONV - POR sells a kit specifically for fuel tanks. I'm not sure how it relates to the POR15 stuff. Per vettefella it sounds like it is closer to $60 or more.
I spoke with a couple of radiator shops and they will de-fume and pressure test the tank for about $30 - then tell me if they can fix it (another $30) or if it is scrap.
Since I plan to keep the car for awhile, I'm leaning towards a new tank.
post #7 of 10 (permalink) Old Jul 14th, 03, 3:28 PM
Sid
Post
Just get a mental pic of your 'velle burning from a fuel leak if an accident occurs. Think I'd go with a new tank....
"Until we, as citizens, become proud of the job our government is doing, no elected official should serve more than one term." TC (Gold) #174
Sid Coleman is offline
post #8 of 10 (permalink) Old Jul 14th, 03, 3:57 PM
Post
I'd let the radiator shop make the call. The Por stuff is more for sealing the inside of the tank if rust is a problem to the point that you're constantly having to change fuel filters, if it's the product I'm thinking about.
A man with an experience will never be at the mercy of a man with an argument.
Randy Mosier is offline
post #9 of 10 (permalink) Old Jul 14th, 03, 5:42 PM
Reid
Post
Their website says that it also "Stops rust & leaks", and "Seals pinholes, seams".
Reid
Rabbit is offline
post #10 of 10 (permalink) Old Jul 14th, 03, 9:18 PM
Post
Try some stukk called KREEM. I have used it and it works great it is also allowed and required on some aircraft(kit type) so I would not be afraid. I did have severe rust problems and used Muratic Acid to clean that first. Then followed directions on the kit and worked perfect no complaints and would use it again.
Mess with me, and you mess with the whole trailer park!
daveseitz is offline
You may not post new threads
You may not post replies
