Camaro gauges in a chevelle - Chevelle Tech
2000 Tech postings from 2000
post #1 of 10 (permalink) Old Sep 19th, 00, 6:09 AM Thread Starter
I brought this question up before,and didn't get any takers, and it is still buzzing around in my head. How difficult would it be to take the round gauges from a mid 70's camaro and install them in my '71 malibu? I have never attempted anything like this, but I like the "factory type" gauge look it would give me. Here is a link to the gauges. I was hoping I could just pull the gauges and make my own faceplate. Whaddya think?
http://cgi.ebay.com/ebaymotors/aw-cg...item=442463937
Trent DuBois
'71 Hugger Orange Chevelle http://www.chevelles.com/showroom/Hugger71.jpg
[This message has been edited by Hugger71 (edited 09-19-2000).]
Hugger71 is offline
post #2 of 10 (permalink) Old Sep 19th, 00, 8:49 AM
I know someone that put those into a 72 Monte once....it looked good,and they worked,but if you know your stuff,it's obviously not correct.But hey,if you're not concerned about originality,why not? They're still "factory" in a way....
1970 Chevelle SS396/L78/M21/4.10
1972 Olds 442 convertible(455,W25,M40)
1982 Oldsmobile Cutlass 350 Olds,TH350(daily driver)
"Be aware of the possible ramifications of the potential outcome"
Chris Corwel,the man from the too much taxes and over priced gas state of Connecticut
mr 4 speed is offline
post #3 of 10 (permalink) Old Sep 19th, 00, 8:57 AM
It'd look a 100 times better than the sweep dash and it would be more factory looking that aftermarket gauges.. I say GO FOR IT!
Joe Y.
68 malibu
Bloomington/Normal, IL
Joe Y is offline
post #4 of 10 (permalink) Old Sep 19th, 00, 9:42 AM Thread Starter
This would be a first attempt for me. Would I need to use the circuit board or could I wire each component separately? I need all the help I can get. Thanks Everyone!!
Hugger71 is offline
post #5 of 10 (permalink) Old Sep 19th, 00, 10:02 AM
Send a message via AIM to BLU69
Hey...
If you manage to make this work post some pics and Info. I would be real interested in how you did it.
Tim
BLU69 is offline
post #6 of 10 (permalink) Old Sep 19th, 00, 11:31 AM
you'll need to wire each component seperately
post #7 of 10 (permalink) Old Sep 19th, 00, 2:48 PM
JWA
If you do this don't buy the gauges off of ebay. I bet you could find a decent deal at the local wrecking yard for a set of camaro gauges. There are usually a dozen or so of these cars in the local yards around here. Good Luck
Jeff Angerstein
ACES#841 TCG#158
68 SS396(454)
68 L78 Project
69 SSRS 396(427) 4spd
87 MC SS
jeffa@chevelles.com
My Chevs
My Favorite
If you don't have time to do it right, make sure you have time to do it over!
JWA is offline
post #8 of 10 (permalink) Old Sep 19th, 00, 3:09 PM Thread Starter
Good idea, Jeff. I think that is exactly what I am going to do. That way if it doesn't work I'm not out of a ton of money. Wish me luck!! I'll need it.
Trent DuBois
Hugger71 is offline
post #9 of 10 (permalink) Old Sep 19th, 00, 3:45 PM
Jeffry
Trent buddy, have you ever looked at factory guages out of the dash? They are ussually not round and mount by sitting in a molded plactic housing. Would not be easy to mount to say a piece of plexiglass. Most all are wired with a printed circuit card which would not even exist for your application. Lighting is another problem as many are not internally lit. Also, factory type guages are not very rugged units and are only tough because of the molded plastic housing there in, which you would not have. It's very possible this could be done but not without an incredible amount of engineering and intricate work. You might want to stick to aftermarket. Theres quite a few different kinds if you dig so you might find one you like.
Jeffry72 is offline
post #10 of 10 (permalink) Old Sep 19th, 00, 4:16 PM
that looks like a lot of work but if you have time check out CHP, they did a newer dash into a 69 camaro, probably didn't cost much but a lot of work too. and boy it looks good, other wise, i'd just buy as set of guages and put them into your sweep speedo, there is a page on doing this and pics on my website below "sweep dash conversion"
Proud new owner of a 1970 SS396 AKA 454/4spd
the darkside has me forever now!!!
My Chev-Hell Page
Member #783
Ft.Worth, Tx
chev-hell is offline
You may not post new threads
You may not post replies
