Setting valve springs close to coil bind - Chevelle Tech
post #1 of 20 (permalink) Old Feb 17th, 17, 1:10 PM Thread Starter
I keep hearing that it's ideal to set the valve spring close to coil bind (0.060-0.075), but how is that possible when dealing with low lift cam shafts?
I have a 1.964 install height (without shims), and a 0.520" cam. With most coil bind specs being in the 1.10 to 1.21 range, how would that be possible? I don't think I would want to run more than a 0.100 worth of shims.
1971 Chevelle SS454 4 speed, 3.31 Posi
-SS454- is online now
post #2 of 20 (permalink) Old Feb 17th, 17, 1:17 PM
Troy
Re: Setting valve springs close to coil bind
I think you'll find seat and open spring pressure more important. If you tries to set it so you approached coil bind your spring pressure would be to high.
66 CHEVELLE
senna is offline
post #3 of 20 (permalink) Old Feb 17th, 17, 1:25 PM
Troy
I think the coil bind specs you listed are probably the minimum you would want to run. Having more is certainly not going to hurt anything. The important thing, as stated above is having the correct installed spring height to produce the appropriate spring pressure for the camshaft you're using.
70 L34 M20 VERT 28-A 791
70 LS5 M40 COUPE 19-19 787
70 LS6 M40 COUPE 14-14 756
69 L78 M21 COUPE 71-B 756
blacknblue is online now
post #4 of 20 (permalink) Old Feb 17th, 17, 1:44 PM
Mr Bill
Chris,
With that small of a cam it really is not an issue. I think it is a lot more important when you have gigantic roller springs and big lift cams. The current thought in those cases is to have the spring about .050 from coil bind at full lift.
Like Troy said, seat pressure and open pressure are more important on most street and mild performance cams. Especially if it is not a roller. Roller cams can tolerate a lot more variation in spring pressures but flat tappet cams cannot.
You need to run whatever spring pressures your cam manufacturer recommends.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Enginerepairshop.com
Team Chevelle #100
BillK is offline
post #5 of 20 (permalink) Old Feb 17th, 17, 1:54 PM Thread Starter
I agree about the pressures. I talked with PAC springs, and they said particularly with a beehive spring you want to install them to run close to coil bind. This reduces the spring vibrations I guess.
post #6 of 20 (permalink) Old Feb 17th, 17, 2:13 PM
Mr Bill
Is this a roller or flat tappet cam ?
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #7 of 20 (permalink) Old Feb 17th, 17, 2:26 PM Thread Starter
Hydraulic Flat Tappet
post #8 of 20 (permalink) Old Feb 17th, 17, 7:23 PM
Troy
On a flat tappet cam, I would run as low a spring pressure as possible.
66 CHEVELLE
senna is offline
post #9 of 20 (permalink) Old Feb 17th, 17, 7:29 PM Thread Starter
Right now I am running Comp 924s. The way they were set up, it seems I only had 97# seat, and 277# open, when brand new. That's just way too low
I'd like to be in the 120-135# seat, and 310-330# open. If I could install 0.15-0.20" from coil bind, it would give me lots of options.
post #10 of 20 (permalink) Old Feb 17th, 17, 7:51 PM
Troy
What's your installed height. Spec calls for 125# @ 1.880 installed height. And 315# @ 1.280 open. I think .015"-.020" is to tight probably want more travel to coil bind.
66 CHEVELLE
senna is offline
post #11 of 20 (permalink) Old Feb 17th, 17, 9:00 PM Thread Starter
Install height without shims is 1.964
The 924s are 112@1.900 and 355@1.200
0.150 to 0.200, not 0.015-0.020. That would allow me to choose from a bunch of different springs, but it goes against the ideal 0.060-0.075 from coil bind.
senna likes this.
post #12 of 20 (permalink) Old Feb 17th, 17, 10:45 PM
Chevelle Doctor
Like Bill said, that's a mild cam. Factory installed BBC height was 1.88" Set them up between 1.88" and 1.90 and run it.
Authentication and pre-purchase inspection service still available. PM me for more information.
Still looking for that elusive 76 Nova SS.
People who have nothing better to do than b!tch about signatures need to get a life.
70 Chevelle L78/M21
10 Avalanche LT 1500 4wd
06 Equinox
Dave Birdwell is offline
post #13 of 20 (permalink) Old Feb 18th, 17, 7:57 PM
Mr Bill
Chris,
Get a set of -50 valve locks. That will put you about 1.915, or put a .060 shim under them all and be done with it.
Unless you plan on turning the engine 6500 rpm on a regular basis, you are just plain overthinking this.
If you really want the extra pressure for some reason, put a .060 and a .015 shim under them. that will put you at about 1.885"
Either way you are nowhere near coil bind.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #14 of 20 (permalink) Old Feb 18th, 17, 11:44 PM Thread Starter
Chris,
You're probably right about over thinking this. I am not concerned about hitting coil bind, even if I go with a larger cam that has 0.554 lift. I am concerned with not setting up close enough to coil bind.
Right now I'm floating the valves past 5500, and I pretty much need it to hold to 6000. Not a big deal.
In any case, I'll get a locator for the bottom which will reduce the install height by 0.060 to 0.062, which will get me right in the ball park where I need to be.
If I could get a tool steel retainer for the 924s, I would be tempted just to use those springs again, as it's very light on the camshaft.
post #15 of 20 (permalink) Old Feb 19th, 17, 2:20 AM
not always good to use drag car racing parts and techniques on a non-drag car.
You check all your valve springs after every 5 or 10 miles of driving?
