Is this crank snout ruined? - Chevelle Tech
post #1 of 15 (permalink) Old Feb 13th, 17, 3:37 AM Thread Starter
Marc
I had to pull the balencer off my 8.1 and this is how it looks. Is this ok or is this ruined?
ID:	421073   Click image for larger version
ID:	421081   Click image for larger version
1970 Chevelle SS 8.1 vortec TKO 600 12 bolt 3.08
1958 Apache 3800 1 ton dually 8.1 vortec 4L80E 14 bolt 5.14
2006 2500HD 8.1 vortec Allison 4.10 4X4
My personal website
http://www.marccuslidge.com/
The 8.1 performance parts store!!
http://www.raylarengineering.com/index.html
1970ss8.1L is offline
post #2 of 15 (permalink) Old Feb 13th, 17, 7:02 AM
Mr Bill
Re: Is this crank snout ruined?
First of all, did you cut the notch n the front of it ???? Have never seen anything like that.
Not ruined but you will need to pull the front cover and use a fine file to get rid of the raised metal where the damper was dragging when you removed it. I would probably replace the damper. You might be able to get in there with a sanding roll on a die grinder and get rid of the deep scars and the raised areas but I would be leery of it.
Before you put on a new damper, you need to measure the crank snout with an accurate micrometer, then take the micrometer and the damper to a good machine shop and have them check the press fit on a Sunnen rod gauge. They can hone the damper to get the proper press fit which on a big block is only .001"
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Enginerepairshop.com
Team Chevelle #100
BillK is offline
post #3 of 15 (permalink) Old Feb 13th, 17, 10:28 AM Thread Starter
Marc
No the 8.1 has the notch and no key.
My personal website
post #4 of 15 (permalink) Old Feb 13th, 17, 11:18 AM
So the notch holds it in place?
it is not whether you win or lose but how you place the blame
64 Nova 400 series
Team Chevelle Gold Member #42
Philip is offline
post #5 of 15 (permalink) Old Feb 13th, 17, 11:35 AM Thread Starter
Marc
I don't know why they notch the 8.1 crank but the balencer is just press fit. When my buddy puts blowers on these blocks they have to have the crank keyed. But n/a this seems to be fine. I'm just not sure if it is going to weaken it or throw the balence off.
My personal website
post #6 of 15 (permalink) Old Feb 13th, 17, 12:24 PM
Mr Bill
Very interesting, I have not seen one yet. I have done a couple of sets of heads but no bottom ends.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #7 of 15 (permalink) Old Feb 13th, 17, 12:55 PM
Hank
If there's no key way what positions the damper accurately on the crankshaft so the timing mark is in the right spot. Looks like there are some more smaller gouges in other areas of the crank. You also have a path for oil seepage between the crank and damper now too.
71 Malibu, 396BBC, 4 speed, 12 bolt.
HKalin is offline
post #8 of 15 (permalink) Old Feb 13th, 17, 1:12 PM Thread Starter
Marc
The 8.1 uses LS style reluctor wheel on the back of crank for timing.
My personal website
post #9 of 15 (permalink) Old Feb 13th, 17, 1:35 PM
Eugene
Those big marks almost look like electrical arc marks.
Bonkerman is offline
post #10 of 15 (permalink) Old Feb 13th, 17, 1:48 PM Thread Starter
Marc
I just talked to Larry at Raylar and he told me that this is common with these and I just need to polish it down and that it needs to have some antiseize on it when re installed.
My personal website
post #11 of 15 (permalink) Old Feb 13th, 17, 2:28 PM
^ balancer probably needs a hone as well. BillK's advice is spot-on - measure it and reinstall with correct dimensions/clearance.
Gary Adrian
The correct spelling is
HILLIARY
Busted Knuckles is offline
post #12 of 15 (permalink) Old Feb 13th, 17, 4:03 PM Thread Starter
Marc
I appreciate the advice on that. I will do that. I ordered a new balencer. I need a different one. The one I took off was from a workhorse 8.1 and the a/c is mounted to high to clear the hood. Also the workhorse brackets stick out further. I ordered brackets and balencer from a siverado. They fit closer to the block and the a/c is mounted down low on the pass side and has Its own belt. It will also be nice to have the same systems on all my 8.1s so all the part numbers will be the same.
ID:	421161   Click image for larger version
My personal website
post #13 of 15 (permalink) Old Feb 13th, 17, 8:57 PM
My balancer came loose a few years ago and chewed up the end of the crank. Probably similar to yours. I filed off the rough edges, installed a harmonic balancer thinking it might reduce possibility of any vibration, a little anti seize and away we go. Have put on several thousand miles with no issues, no vibration. But always conscious that it could fail anytime.
Mind you I am running a stock 327 and not overworking things. If it fails I will get my spare rebuilt and drop that in
Dunc
'Just because you are paranoid doesn't mean they are not out to get you' - unknown
pduncan is offline
post #14 of 15 (permalink) Old Feb 14th, 17, 3:05 AM Thread Starter
Marc
I'm just going to run it. I have a spare 8.1 but if this engine craps out I will just pick up a Raylar 540 crate motor.
My personal website
post #15 of 15 (permalink) Old Feb 14th, 17, 6:53 AM
I would run it. It appears like it was possibly made that way to hold a supercharger pulley or something on it. I would run it. Polish it up and no pulkey. It's press so your golden... my 1st car was a geo tracker when I was 15 I bought new light underdrive pulley (before i really underdtood things fully) and it ruined my crank snout... so I emory cloth the hell out of it and I cut up A sprite can to go all the way around crank snout tapped pulley on with hammer and it went for a another year or 2. I then held throttle to floor until It blew. I put a 4.3 vortec and manual trans... never worked property many problems it's sucked so I trashed it again not enough no how and no help had minimal tool's and money.
anthoney456 is offline
