Is there a way to make a Holley less cold natured? - Page 2 - Chevelle Tech
 4Likes
post #16 of 25 (permalink) Old Jan 9th, 17, 2:58 PM
Re: Is there a way to make a Holley less cold natured?
I had a 650 DP before I switched over to EFI. It was always really cold on start ups, even in the summer, but not as bad. I normally would pump the pedal 3 times, then crank it over. Typically would work well, but I would have to hold my foot on the gas for a minute or two. I had a manual choke hooked up, but it would get stuck, causing the motor to be choked when driving around. Hence why I stopped using it...
69Chvll is online now
post #17 of 25 (permalink) Old Jan 9th, 17, 4:22 PM
Originally Posted by p40 View Post
not being a smart a&& dean but i dont think a lot of people know what a god ol fashion hand choke is
Don't they use that in MMA?
nitrofox is online now
post #18 of 25 (permalink) Old Jan 9th, 17, 5:29 PM
It's why so many young boys didn't go blind, but needed glasses at an early age........
The Deejay is online now
post #19 of 25 (permalink) Old Jan 9th, 17, 8:05 PM
Buy a quadrajet!
'67 Chevelle in hibernation.
cozmacozmy is offline
post #20 of 25 (permalink) Old Jan 10th, 17, 2:41 AM
there is that.....
post #21 of 25 (permalink) Old Jan 10th, 17, 9:43 AM
If your running an HEI it has about 17-23* f mechanical advance. As stated above you need more initial advance, try 16*. Also make sure your HEI has full battery voltage connected, no resistance wire. In addition make sure the HEI has voltage during cranking. The old saying that most carb problems are ignition related is true. You should have no trouble starting the engine with no choke other than having to maintain idle with your foot.
2006 Ford Mustang GT (momma's car)
2006 Ford Mustang Coupe (kids car)
http://s1141.photobucket.com/albums/n587/oldcutlass/
http://s1141.photobucket.com/albums/...lass/plymouth/
oldcutlass is offline
post #22 of 25 (permalink) Old Jan 10th, 17, 4:19 PM
Originally Posted by cozmacozmy View Post
Buy a quadrajet!
cozmacozmy likes this.
77 Monte
421 Profilers ported by Eric W. Straub HR 3200 conv. from Jake 200-4r w/ 3.73's
12.15 @ 112 & tuning
http://myweb.midco.net/77cruiser/
77 cruiser is online now
post #23 of 25 (permalink) Old Jan 16th, 17, 9:39 PM
Best solution is to replace it with an Edlebrock !!!
rwin1592 is offline
post #24 of 25 (permalink) Old Jan 16th, 17, 10:09 PM
77 Monte
post #25 of 25 (permalink) Old Jan 17th, 17, 9:08 PM
X3 on more initial timing. 10 BTDC is not even for anything other than an absolutely stock cam.
I've run Holley's and Eddy's with no choke. For really really cold starts you need a choke. For everything else you can sit with it and warm it up with your foot without a choke A properly tuned choke will allow you to start, warm up, idle down and drive with very little effort. It's worth the investment in parts and investment in time to tune it.
Zeke
67 Chevelle
64 Chevelle
90 Corvette ZR1
TC# 3094 ACES# 7297
zeke67 is offline
