4 bolt main caps on a 2 bolt main 454? - Chevelle Tech
post #1 of 3 (permalink) Old May 3rd, 05, 10:22 AM Thread Starter
Just pulled the pan on the 454 I got for the Barbie Elky, The engine came out of a 81 pick-up. It has 4 bolt main caps but only two of the holes are being used and the block has not been drilled or tapped for 4 bolt. Was this a common thing for GM?
When I asked my engine guru he said that the caps must have been replaced and the prior rebuilder didn't bother to have the block drilled & tapped. I always thought that if you replace the caps you have to line bore the engine to make it match the new caps. So why not drill & tap at the same time?
Checked the archives.....nothing there.
Thanks,
Ron
69 El Camino, no longer Barbie Pink.... Is now Rusty Pearl!!
99 Mustang GT (his)
04 Kia Amanti (hers)
95 Geo Metro (beater)
If you cut out drinking and smoking, soon you'll be cutting out little paper dolls in the loony bin!
freakinbarbie69 is offline
post #2 of 3 (permalink) Old May 3rd, 05, 12:33 PM
Re: 4 bolt main caps on a 2 bolt main 454?
I've seen a small-block 400 where the block was drilled but not tapped for the outer bolts, and then GM installed two-bolt caps on it.
I'll believe 'most anything when it comes to production line screwups.
Schurkey is offline
post #3 of 3 (permalink) Old May 3rd, 05, 12:36 PM
Wally
Guest
Posts: n/a
Smile Re: 4 bolt main caps on a 2 bolt main 454?
Thanks,
Well, the short answer is he was lazy, but they maynot have had the necessary tooling to do the job right. You just don't drill some holes and tap them. There's counter bore to deal with, the depth is critical as you can crash out at the bottom. Then the taps are a whole different ball game, and last but not least, a nice big narly vertical mill with enough room under the milling head to do the job.
Milodon 4 Bolt Main Caps on a RAT Ron454 Performance 2 Sep 7th, 04 4:16 PM
BBC 4 bolt main conversion? Kx69 Performance 13 Jan 5th, 04 8:23 PM
70 Malibu Door Alignment Help Chevellehell Body Shop 2 Oct 10th, 03 11:34 AM
Two bolt main to four bolt mark67ss 1999 -- 2 Jun 16th, 99 6:15 PM
