How easy is it??? - Chevelle Tech
post #1 of 24 (permalink) Old Oct 4th, 15, 10:56 PM Thread Starter
Jay
How easy is it???
Hello there, I would like to know if it is easy to drill and tap a hole in what I think is where the bellcrank ball stud threads into the side of the block. I will try to post some pictures & hope I don't have to re size them being I have no clue in how to do that. Pic one is a known 194 cid block & pic two is a 230 cid block that I think is from a Chevelle, casting #'s are 3877178 with suffix # code F0525CC the * CC * I have found in my Chilton's repair manuel coming from a year code 65-67 230 PG trans. My car (chevy II) is a manuel 3 on the tree car. This is why I would like to know if it is possible to drill & tap a hole for the bellcrank ball stud
Name:	6 cyl 004.jpg
ID:	302249   Click image for larger version
Name:	6 cyl 005.jpg
jay gordon is offline
post #2 of 24 (permalink) Old Oct 5th, 15, 10:54 AM
Broc
Re: How easy is it???
Should not be that tough. Get the engine level and get a drill with a level glass or LED's so you can hold it level and square. Tape a carpenters square nearby so you can watch it and keep yourself in the ball park. Tape the drill's so you don't go to deep. That is tape around the drill at the depth you want to stop.
What size and thread is the bell crank ball stud? Looks like 3/8 or 7/16 on first glance...
I'd work my way up in drill size. You'll maybe need two taps to get it done. A standard to do most of the threading work and a bottom tap to finish. Use lots of cutting oil for the drills and the taps
BrocLuno is offline
post #3 of 24 (permalink) Old Oct 5th, 15, 11:55 PM Thread Starter
Jay
Not 7/16" or 3/8". It is a 1/2" x 1" deep, I haven't gone looking for my bell crank ball stud yet so I measured how deep it is and fitted some bolts and found the size that way. Was hoping I could do it at home & not have to take it to a machine shop, Thanks Broc.
Not a text guy just a phone guy
post #4 of 24 (permalink) Old Oct 6th, 15, 12:16 AM Thread Starter
Jay
Does anybody know what these holes are???
The same side location has 2 other holes just up & a little left, also with a larger hole on the left side rear of eng.(fin) at the right of the bell crank ball stud. My 194 didn't have these holes it was a ChevyII block though, this one I think is a Chevelle eng. All casting #'s & suffix code is up in my original post. I can't insert a pic of the engine so you will have to look at my original post from above, the eng that is dirty is the one to ID , Thanks, Jay
post #5 of 24 (permalink) Old Oct 6th, 15, 7:08 AM
Hank
I don't know where your trying to drill a hole. The orange block already looks like it has the hole your referring to for the bell crank which would be the hole closest to where the bell housing will bolt up to and the other block has no casting material in that same area.
HKalin is offline
post #6 of 24 (permalink) Old Oct 6th, 15, 7:25 PM Thread Starter
Jay
HKalin. I have a Chevy II that needs the engine. In my original post is two engines one is clean that is a Chevy II 194 eng with the mounting hole for the bellcrank ball stud at the bottom where the oil pan would meet the eng, that eng (no paint) is no good. The orange painted eng is the one that I ask if it could be Drilled & taped, got my answer for that. From you only half of my question was answered. That mounting hole you pointed to I guess is where the bellcrank ball would mount for the Chevelle eng. and that mounting hole doesn't do me any good in using my old Chevy II Clutch Bellcrank lever for my Chevy II. I am just going to use the Chevelle eng (orange eng.) in place of the Chevy II eng cause that eng is like being the next LOTO winner pretty much not going to happen. If you could answer the 2nd part of my last question for the two other holes just under the freeze plug that would be great, just curious in what mounts there? Thanks
post #7 of 24 (permalink) Old Jan 10th, 17, 4:34 PM Thread Starter
Jay
T T T please. question not answered yet for the two holes
post #8 of 24 (permalink) Old Jan 10th, 17, 7:57 PM
Why don't you make up a drill guide jig using the 194 block as a basis? Then bolt that jig to the 230 block and drill the hole. Then use that jig to also tap the hole straight. That way the ball stud geometry will be duplicated and correct. Rather than the hole being drilled by eye and ending up on the piss.
chrisstandring is offline
post #9 of 24 (permalink) Old Jan 10th, 17, 8:22 PM
I had some friends that had early Nova's in the 90's. A couple of them used later blocks that didn't have a provision for the ball in the same location as a factory Nova block. I recall they said someone made a bolt on adapter that would center the ball in the location as if it were a Nova block. They said they bought it at a specialty Nova supplier. It may be worth calling around to see if someone offers an adapter that will work for your application.
Good luck.
Steve R
Steve R is offline
post #10 of 24 (permalink) Old Jan 10th, 17, 8:41 PM
Does it really matter what the two holes were for since they're not even close to where you need the bell crank hole?
post #11 of 24 (permalink) Old Jan 10th, 17, 10:36 PM
Eugene
Those two holes are for the clutch linkage on a pickup around the 64 65 vintage, I think. If I recall there was a bracket that bolted on there and then the pivot was on the middle of the bracket. It was kind of a U shape that moved the ball out from the block about 2.5-3 inches. I can not remember what the old vans used but I am pretty sure that is what the pickups used.
Bonkerman is offline
post #12 of 24 (permalink) Old Jan 11th, 17, 1:24 AM
there is a bolt on bracket. look at the Nova vendors.
post #13 of 24 (permalink) Old Jan 11th, 17, 1:53 AM
Lang
If you do decide to drill it, as mentioned above a fixture to locate the hole is the best way to go. Cast Iron is not that hard to drill and tap, but you do need to use lube and it has to be located spot on. You don't need a Machine Shop to do this.
langss is offline
post #14 of 24 (permalink) Old Jan 11th, 17, 2:34 AM
Larry
Hi , here is the bell crank in my sons 71 Nova with 250ci , if that doesn't suit the early nova you might have to build a bracket off the existing holes to get it closer , my 6 cylinder biscayne has a factory bracket off the engine with the ball stud attached,
Cowfarmer is offline
post #15 of 24 (permalink) Old Jan 11th, 17, 4:04 PM
Larry
I didn't see before but Tom already mentioned there is a bolt on bracket available, that is the way to go
