quick fuel metering block conversion kit - Chevelle Tech
post #1 of 5 (permalink) Old Sep 9th, 13, 4:21 PM Thread Starter
Will Smith
I have a 750 holley double pumper 4150. I need to new metering blocks and I found that quick fuel makes a metering block conversion kit. I was wondering if anyone has tried this kit. I wasn't sure if this kit was good or bad so if anyone could give some input.
71 Chevelle - 454 , Lunati cam, forged crank, 12 bolt posi with 4.11 gears, silver with black stripes, speed pro pistions, crowler connecting rods, oval ported heads, 750 dual pumper carb, eldabrok victor jr. intake, turbo 400 transmission
willie16wild is offline
post #2 of 5 (permalink) Old Sep 9th, 13, 4:27 PM
Re: quick fuel metering block conversion kit
why do you need new metering blocks?
Please remove the car for sale ad from your sig.
post #3 of 5 (permalink) Old Sep 9th, 13, 5:17 PM
Vinny Vince
Do yourself a huge favor and by a set of replacement Holley blocks. Carbs are hard enough to tune let alone a modified one.
*11 C6, 6.2, 6spd
69-CHVL is offline
post #4 of 5 (permalink) Old Sep 9th, 13, 9:54 PM Thread Starter
Will Smith
Cause I bought this carb for 100$ used and the metering blocks were modified. And my throttle plates were drilled and I need new ones of those too. So I need new metering blocks and throttle plates.
I would maybe be able to make the metering blocks I have if I smaller holes in my throttle plates.
These quick fuel metering blocks looks pretty cool and plus from what quick fuel says about them. They should be good but I need to make sure first.
post #5 of 5 (permalink) Old Sep 9th, 13, 9:58 PM Thread Starter
Will Smith
I should be able to tune it pretty easy as long as it does what it says. They sound good but I need to make sure first before I buy them. There like the same price if not less.
This Thread is more than 1326 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
