69 396(325HP)cam recommendation - Chevelle Tech
post #1 of 10 (permalink) Old Dec 9th, 12, 1:55 AM Thread Starter
Rob
Stock 325 hp engine(.60 over), original heads with stock valve train, intake, carb, etc. automatic. Looking for a cam recommendation for rebuild. Looking for some increased initial acceleration while maintaining close to stock idle.
Thanks....
socalss is offline
post #2 of 10 (permalink) Old Dec 9th, 12, 3:53 AM
z27
alex
Re: 69 396(325HP)cam recommendation
Well Rob! It looks like you wan,t your cake and wan,t to eat it too.You are asking for quick acceleration {throttle response} and wan,t a near stock idle. The two don,t go hand in hand .I think what you are looking for is {seat of the pants when you pour the coals to it ,that,s torque} for that you would need a cam on a 110 or 108 lobe separation. That will not give you a stock type idle, it will be a little lumpy but if you don,t go crazy on duration the idle will be noticable but livable. On the other hand you could use a cam that,s on a 112or 114 separation angle and that will smoothen the idle out and spread the torque over a wider band but that will negate the seat of the pants feeling when you nail it.I hope this helps you and that i understood your question correctly. Alex
z27 is offline
post #3 of 10 (permalink) Old Dec 9th, 12, 9:42 AM
mr
Don
Re: 69 396 (325HP) cam recommendation
Originally Posted by cstraub View Post
In no way,
will an OEM headed BBC engine, ever be optimized, by an single pattern cam if the heads have been untouched.
The 2.065" valve has enough area to feed 430 CID to 6200 rpm...
Heads and cam, are the power of the engine.
You need to decide what you want out of the engine, and then move forward on selecting parts.
The cams job is to do the thinking for the engine.
............... The cam controls the air/fuel going in-and-the exhaust going out.
1) it has to know what size the engine is ...
2) what rpm it needs to go to in order to make power ...
3) how much heads can flow in and out ...
Knowing all 3 of the above, camshaft selection is black and white ...
Without knowing what the heads airflow is your guess at a cam is as good as anyone on this board.
Duration is the ability to make power/sustain power at a given rpm range.
.......... Added duration that is not needed makes an engine peaky, narrows the powerband.
At low rpm's you need to open the valve sooner, and get the air in since the head, does not have velocity at low rpm.
As the rpm grows the intake valve can be opened later, as the velocity is there.
At the point we open the exhaust valve, it is under extreme pressure, so as soon as the valve leaves the seat the exhaust leaves the cylinder.
The exhaust gas velocity is at it greatest at this point, much like a bullet leaving the barrel.
Holding the exhaust valve open longer just blows torque out the pipe.
I'd recommend a cam with moderately high lift [in the .550" range] & a moderate amount of duration [225°/235°@.050]
Something similar to the [quote] cams listed below, for a stock type 396 BBC.
Comp Cams Xtreme Marine, XM 270H-12 [11-236-4] XM270H 270 286 [226°/236° .544/.547 112°]
Comp Cams Xtreme 4X4 profile, X4 270H-11 [11-239-3] X4 270H 270 278 [226°/234° .544/.564 111°]
HP Value? BBC Hydraulic to Retro-Roller
http://www.corvettefever.com/techart...g/viewall.html
__________________________________________________
....... "drag racers do it , till their rubber smokes" .....
mr is offline
post #4 of 10 (permalink) Old Dec 9th, 12, 10:03 AM
Put in a Lunati 60202 flat tappet hydraulic and new stock or slightly stronger valve springs and don't look back. It will have a nice idle with a bit of pop to it and all the stock parts will remain compatible. The stockish springs will assure a drama free break in and reliability. Ask for the hardened lifters from Lunati. This will wake up the 325 without making it radical. It will rev nicely to near 6,000 and will be a fun ride all around. Basically, it will put it into a direct comparison to a stock 360 HP. Of the day. FWIW, Ed.
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is offline
post #5 of 10 (permalink) Old Dec 9th, 12, 11:37 AM
I understand what you are looking for. You might want to look at the cam I have in my 1966 396/325. It is an Isky 270 Megacam,(HFT),and I had it ground on a 112 lsa. The cam come on a 108 lsa,too choppy for me,and I wanted to keep the vacuum up. I used all Isky though out the whole valvetrain. I am very happy with it...Bob
MCC#826
T/C#4889
A.C.E.S#08597
Baltimore-06C
1966 SS 396/325,M-21,P/S,P/B,.331 Posi.
Marina Blue,White Interior,Wood Steering Wheel
'66 AM/FM Delco,Knee Knocker Tachometer
Boyd Coddington 17" Magneatos
Rotisserie Restored-Matching Numbers
95% Original Chevrolet-5% Original Bob
http://www.chevelles.com/forums/members/46025-bob-s66396-albums-bob-s-1966-ss-396-super-sport.html
Bob's66396 is offline
post #6 of 10 (permalink) Old Dec 9th, 12, 1:18 PM
mr
Don
Thumbs up Re: 69 396(325HP)cam recommendation
=Advertised Duration (Int/Exh): 262/268-Lunati #60202
Duration @ .050 (Int/Exh): 219°/227°
Gross Valve Lift (Int/Exh): .530"/.542"
LSA/ICL: 112°/108°
It is an Isky 270 Megacam, (HFT), I had it ground on a 112 lsa. The cam come on a 108 lsa, too choppy for me, and I wanted to keep the vacuum up. I used all Isky though out the whole valvetrain. I am very happy with it.
=Advertised Duration (Int/Exh): 270/270-Isky 270 Megacam
Duration @ .050 (Int/Exh): 221°/221°
Gross Valve Lift (Int/Exh): .542"/.542"
LSA/ICL: 112°/108°
Originally Posted by badrad View Post
My favorite cam for this type of build is the Isky Mega 270/280, same as the Isky listed above but with more exhaust duration for better breathing. It has mild manners on the street and makes really good TQ.
=Advertised Duration (Int/Exh): 270/280-MEGA
Duration @ .050 (Int/Exh): 221°/232°
Gross Valve Lift (Int/Exh): .542"/.565"
LC: 114°
All the cams mentioned above, should be provide major power improvements, to your 396 ...
L-35 specs: 396 CID produced 325 hp, from 1965-thru-1969, had 10.25:1 compression, Q-jet carburetor, hydraulic lifters, oval port closed chamber heads, and two-bolt main caps.
I believe these are the camshaft specs, for your stock 1969 Chevrolet 396 325 hp/L35.
Camshaft number = #3874872
Camshaft Intake duration @ .050" == 196°
Camshaft Exhaust duration @ .050" = 196°
Camshaft lift - Intake == 0.398"
Camshaft lift - Exhaust = 0.398"
@ 114° LSA
1969 Chevrolet 396 w/L35 engine.
C.R. = 10.25:1
Horsepower = 325 @ 4000
Torque = 410 @ 3200
I believe these would be the correct camshaft specs, for a 1970 Chevrolet 402 w/L34.
The duration figures, which are taken at .008-inch lift are 268° int./ 274° exh.
Camshaft number = #3883986
Camshaft Intake duration @ .050" == 214°
Camshaft Exhaust duration @ .050" = 218°
Camshaft lift - Intake == 0.461"
Camshaft lift - Exhaust = 0.480"
@ 115° LSA
1970 Chevrolet 402 w/L34 engine.
C.R. = 10.25:1
Horsepower = 350 @ 5200
Torque = 415 @ 3400
I believe these are the correct "solid lifter camshaft specs", for a 1969 Chevrolet 396 w/L78.
Camshaft number = #3863148
Camshaft Intake duration @ .050" == 242°
Camshaft Exhaust duration @ .050" = 242°
Camshaft lift - Intake == 0.520"
Camshaft lift - Exhaust = 0.520"
@ 114° LSA
1969 Chevrolet 396 w/L78 engine.
C.R. = 11.25:1
Horsepower = 375 @ 5600
Torque = 415 @ 3600
NOTE: there is supposedly an -8° duration difference, between the specs on a "hydraulic cam" & a "solid lifter camshaft".
* take this 1969 L78 solid camshaft, if it were a hydraulic lifter camshaft, duration would be approximately 234° @.050"
Duration split ... You can manipulate the valve events and duration split to achieve vacuum.
I do a ton of vacuum rule cams in both circle track and truck pull.
Street cars worry about brakes, sanctioning bodies use vacuum rules to limit camshafts.
Pulling 15" vacuum @ 1000 rpm is doable with a 240° range camshaft on a 106° or 107°.
mr is offline
post #7 of 10 (permalink) Old Dec 9th, 12, 1:29 PM Thread Starter
Rob
That sounds like a nice, simple solution to what I'm looking for. I think I will either do as you suggested, or build it to 69 396 350hp specs, which if I undestand correctly, only differed in the cam and possibly the carb jetting. Sounds like either direction will give me what I'm looking for.
Thanks.....
socalss is offline
post #8 of 10 (permalink) Old Dec 9th, 12, 3:13 PM
jimmyradford
My favorite cam for this type of build is the Isky Mega 270/280, same as the Isky listed above but with more exhaust duration for better breathing. It has mild manners on the street and makes really good TQ. What part of SoCal are you in?
TC Member # 4431
'04 Ram Quad-That thing has a Hemi in it!
'68 El Camino-SB 350/TH400/???
'67 Hell Camino-BB 496/TH400/???
'55 BelAir 2 door post-427/TH-400/4.10
"Good people sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf."-Orsen Wells
badrad is offline
post #9 of 10 (permalink) Old Dec 9th, 12, 4:05 PM
X2 on the Isky stuff. Call Isky, ask for Rod, tell him what you are trying to achieve and he will hook you up or call Mike at Wolfplace, he sell's Isky part's.
'66 SS Chevelle
565 BBC Mamofied 300cc Ovals
Best e.t. 6.32@98mph licensing
"seize the day", live and thrive
Stokerboats is offline
post #10 of 10 (permalink) Old Dec 10th, 12, 6:38 PM
George
Thanks.....
the 325 cam is a loser
the 350 horse cam is next to last place...
lots of modern cams out there that will do for you what needs doing
George Kettler
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
kettbo is online now
