How much should I pay for machine shop for a 283? - Chevelle Tech
post #1 of 20 (permalink) Old Aug 3rd, 12, 10:31 AM Thread Starter
I was going to reuse the original 283 in the car. It is tore apart and nothing looks too bad. The cam is wore out which I was going to replace anyhow. I called a local machine shop just to rebuild the bottom end and he wants to use a master kit. He would supply the master kit. I don't there is anything special, just a basic kit. I was quoted 1200 for this. This is to replace cam bearings, freeze plugs, hot tank, new pistons and assembly. This doesn't include anything for the top end. Is this the going rate ( I know prices will differ by area)? This is getting into a used LS1 conversion price. A basic crate 350 is what 1700? I dont know the finance manager(ie the wife) will like this. I am looking for something to cruise around in. Any recommendations on engine kits? There is another machine shop I am going to check out. My father used to rebuild his own in the 60's. I think he might be coming out of retirement on this one.
1964 Chevelle Convertible 283 3 on the Tree
1964 Chevelle Convertible 230 powerslip
chevelle malibu 64 is offline
post #2 of 20 (permalink) Old Aug 3rd, 12, 10:40 AM
Re: How much should I pay for machine shop for a 283?
Depends on what kind of rebuild on the 283 your looking to have done. Does it need to be bored and have new pistons? $1200 for a stock rebuilt shortblock seems pricy to me, but I'm cheap by necessity. If you were in my area I could point you to several quality shops that would fix you for significantly less than that price.
Middleagecrisis is offline
post #3 of 20 (permalink) Old Aug 3rd, 12, 12:33 PM
Rich
Rebuilding the 283 is more expensive than some of the other small blocks due to the more expensive rebuild kits. Just a little more specific market. The 283 'cool' factor is high, though. Go for it. Remember when picking a cam that the numbers are for a 350... Go one step less aggressive in a smaller motor. Just my 2 cents...
Rich
---1965 Malibu SS Ragtop 283/416 heads/700r4
---2009 Corvette Coupe
"Whatever it is, I'm against it." --Groucho Marx
richietables is offline
post #4 of 20 (permalink) Old Aug 3rd, 12, 1:13 PM
leo
JMHO, go with the GM crate. My machinist says that rebuilding the 283 and 327 costs more than a 350. Good luck with your choice.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
www.mdchevelleclub.com
LeoP is offline
post #5 of 20 (permalink) Old Aug 3rd, 12, 5:54 PM
Rod
In central California, my machine guys machineing prices for the bottom end of the engine should be around $300-$400, crank about $150 to turn assuming yours is usable, and the master kit should be around $600. This doesn't include if he is going to do the assembly. The masterkit should come with a stock/oem replacement cam. Upgrading the cam should be around $100-$200. If I remember correctly heads are $150 to check, and another $400 to rebuild with new parts.
9 years and FINALLY she's drivable, just in time for my first born son.
My_two_tone_'64
Rod Hill
IT/AG instructor
Ag. Mechanics, Ag. Power Mechanics, Ag. Wood
Los Banos High
Los Banos California
twotone64 is offline
post #6 of 20 (permalink) Old Aug 3rd, 12, 10:19 PM
rkd
Ron
If that includes the parts and machine work, and assembly, its a good price.
I spent a bit more than that on my 350 and did the assembly myself.
A 283 does have a cool factor to me in an early Chevelle.
rkd is offline
post #7 of 20 (permalink) Old Aug 3rd, 12, 11:13 PM
Derrick
do this.. get a replacement engine for a 92ish Caprice with a 350.. it comes with PM rods, hypereutectic pistons that have 9:1 compression, a decent roller cam, and makes almost 300hp with headers.. paint it orange and drop it in with all the stock accessories, and you can make it look almost like the 283 if you get adapters to run perimeter bolt valve covers..
last i checked this engine was right in the $1500 range- which is a killer deal for an all new 300hp engine with a warranty..
or there is also the idea of doing a 4.8 or 5.3 swap, which would come in at around the same price if you go with a good junkyard engine and do the work to put it in and get it running yourself.
-Hank Hill
novaderrik is offline
post #8 of 20 (permalink) Old Aug 4th, 12, 2:46 AM
...or just drive out and buy my ready-to-go 283 for $450.
64play is offline
post #9 of 20 (permalink) Old Aug 4th, 12, 11:46 AM
Lang
If your not in a hurry to get this up and running, and can wait until the Thanksgiving Holiday, Every year as far back as I can remember http://sdparts.reachlocal.com/?scid=..._id=5873201138 has had a sale on the Goodwrench 350. I got one of these a few years ago for my Truck. it came with an Edelbrock Performer,Gaskets, and Bolts + free shipping. That all may have changed, but just the same for the engine alone, its a pretty good deal.
langss is offline
post #10 of 20 (permalink) Old Aug 4th, 12, 9:27 PM
jim
I say do like Derrick says. $1200 for the bottom end, then you have to do the heads, and to do them right you'll want to put in hardened seats for the unleaded fuel, a valve job, the guides may need done. Anyway you're looking at about 500plus or minus 100 added to the 1200. You can buy a crate motor with a warranty for about the same outlay. The hi-po crates are the way to go unless you want bone stock or all out racing.
shomejim is offline
post #11 of 20 (permalink) Old Aug 5th, 12, 1:52 AM
Sam
Cheapest 350 short block rebuild (machined .30 over w/ cast pistons, rings, bearings, RV cam, double roller timing set and a full gasket set) I could find in L.A. was $575. I think that's about the bottom for a short block rebuild.
'70 El Camino
SamSnyder is offline
post #12 of 20 (permalink) Old Aug 6th, 12, 10:35 AM Thread Starter
I really want to keep it the 283 in it. Dont see many around anymore. Also keeping the 3 speed on the tree. I have a set of 416 305 heads that have already been machined. Going to check a couple of other speed shops and see how much just to clean, check the block and crank and put in cam bearings and freeze plugs. The last engine my Dad built was in 1991, and it is still going strong, so I am going to see if he can do another one.
post #13 of 20 (permalink) Old Aug 6th, 12, 12:34 PM
Rich
Glad you're planning to keep the 283... I have 416's on mine, eddy dual plane intake and eddy 500 cfm carb. Really a strong and reliable little motor...
Rich
post #14 of 20 (permalink) Old Aug 10th, 12, 3:45 PM Thread Starter
I took the 283 to another machine shop today. Even less thrilled with this one. Didn't like the 416 heads I have. Would only guarantee the engine if he assemblied the long block and used his heads which he would do a valve job on. The quote was over well over $2000 but would knock 300 off if I paid all up front. I know the engine needs bored out. There is a pretty good ridge on top of the cylinders. The parts was going to be over 750. Wanted to deck the block, line hone etc.. said all blocks have problems. I asked about a crate engine, seeing if they sold their version of one. All I got was crate engines are massed produce and not very good. This car isn't one of 20 or rare or anything, just wanted the 283 to be different. He is going to hot tank the engine and magnaflux it to look for cracks. Told him would think about the rest of the work over the weekend and give them a call on Monday. Well actually, I barely left the parkling lot. It's not going to happen. Going to pick it back up, take it somewhere else and have it bored and going to have my Dad help me assembly it. Anybody know of good place for 283 master engine kits?
post #15 of 20 (permalink) Old Aug 10th, 12, 6:16 PM
Ray
This is just an option here so please take it for what it is worth. I know it is low buck but spending 2k+ is not always an option. At least not always for guys like me.
I would be considering simply taking it apart. Honing the cylinders. Having the block hot tanked. New Cam bearing, freeze plugs and putting it together w/ new rings and bearings. Chose a flat tappet cam and use your 416 heads.
This would be the cheapest by far. Look at Northern for a Re-ring kit and bearing kit and go. New oil pump too since the cam went. Probably only have a couple of hundred in it all together.
Hate to say it but had the cam not gone flat I may not have even hot tanked it but you want to make sure you get all the metal out before reassembly. Have done it before and have had a blast with the low buck engines.
If you have a ring compressor and a torque wrench you are set. Engine stand would be nice but I have done it w/o already.
Just an option.
rortwein is offline
This Thread is more than 1719 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
