396 bored to 427? - Chevelle Tech
post #1 of 15 (permalink) Old Oct 20th, 11, 8:32 PM Thread Starter
alex
396 bored to 427?
I was wondering if anyone has bored a 396 to a 427? I know its possible to do this. But i dont want to waste a good 396 block to do it. So i was wondering if anyone had done it. Thanks
chevyl69 is offline
post #2 of 15 (permalink) Old Oct 20th, 11, 9:23 PM
Tim
Re: 396 bored to 427?
I'm not really a big block guy, but that would be .125" to go from a 402 to 427. It would be .155" from a 396. It seems like a lot to me. I found one casting number on Mortec , 3855961, that was common to both 396 and 427.
Here is the link to Mortec --> MorTec Chevy V-8 Big Block Casting Numbers
Tim Shea
72 Malibu w/ZZ4, Muncie M20 and 3.73 12-bolt.
tpshea is offline
post #3 of 15 (permalink) Old Oct 20th, 11, 9:29 PM
Tim
Alex,
You might get more activity on your question if you put it in performance. I think it can be moved there, but I don't know how. Just a thought.
Tim Shea
tpshea is offline
post #4 of 15 (permalink) Old Oct 20th, 11, 9:48 PM Thread Starter
alex
Tim, Thanks for the info.
chevyl69 is offline
post #5 of 15 (permalink) Old Oct 20th, 11, 10:08 PM
From what i understand the 961 bbc was the only block that GM used for production 396 & a limited amount of 427s in late 1965 into 1966 when the 427 introduced . (maybe 67 too but not sure of that)
BTW,not all 1965-66 961 bbc 396 & 427 blocks were able to handle the larger 427 bore,they need to be sonic tested 1st.
Another supposed way to confirm if 961 block was able to go to 427 bore was if you can't get a std size pencil inbetween the cyls in water jacket when trying it thru freeze out plug hole in a 961 bbc block it meant the cyls were thicker alowing for the 427's larger bore.
But i have never expericned that for myself ,i had a 66 961 spare motor (396) with 840 heads approx 12-13 yrs ago with L78 intake,steel crank,dimple rods with large bolts,etc.
I sold it to a guy restoring a 66 chevelle ss 396/360hp 4spd for $600,paid $125 for it 10yrs prior so did ok on it.
Other then the 961 block other 396/402 blocks would not normally safely handle the larger 427 bore when using a stock 396/427 crank /stroke to achieve it & not a stroker crank to make for ex a 434 bbc stroker motor from a 396 or 402 bbc block.
SCOTT
SWHEATON is offline
post #6 of 15 (permalink) Old Oct 20th, 11, 10:16 PM
Originally Posted by tpshea View Post
Alex,
Engine forum is a good place for this post,not off base IMHO.
SCOTT
SWHEATON is offline
post #7 of 15 (permalink) Old Oct 20th, 11, 10:20 PM
I've had done it to two 396 blocks in the 1980s. Worked out good for me. Some two bolt 396 blocks were built with 427 castings. Some 4 bolt 396 also had very thick cylinder walls.
You should at the very least inspect the block for core shift. If it looks reasonable than you will need to do the "pencil test".
Remove the center freeze plug. If a normal yellow pencil will NOT fit between the bores in the water jacket than it should work out for you.
I used a 66 two bolt and a 67 or 68 4 bolt block to do the two I did.
Buster is offline
post #8 of 15 (permalink) Old Oct 20th, 11, 10:24 PM
Jon
Don't waste the block, use a 454 from the 70's with the 396 internals. I did this and it has worked out great.
jvoiles is offline
post #9 of 15 (permalink) Old Oct 20th, 11, 11:12 PM
Derrick
that won't work with about .5% of the people that will ever look under the hood if you're trying to disguise a bigger engine as a stock 396..
-Hank Hill
novaderrik is online now
post #10 of 15 (permalink) Old Oct 21st, 11, 8:20 AM
A pencil will always fit between the bores, even on a 289 casting 454 block.
On a 427, 454 or thicker 396, it just BARELY fits - there's around 1/4" or less between the cylinders. On a run-of-the-mill 396, that gap is a lot closer to 1/2".
Have it sonic tested. One thing for sure, it won't have clearance for a stroker crank, you'll have to do some grinding.
I'd find a solid 454 casting and someone who needs the 396 for a resto build. Even if you bore it .125, that's gonna cost you some coin from your builder, it takes a while to cut that much out of each cylinder.
Gary Adrian
The correct spelling is
HILLIARY
Busted Knuckles is offline
post #11 of 15 (permalink) Old Oct 21st, 11, 9:00 AM
If it were me, I would find a 454 block and use the 396 crank and rods. Now you have a 427. A 396 isn't bad either. Unless you plan on going to the track with it, they all will spin the tires on the street. And 500 hp out of a 396 is faster than most realize.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.034 at 148.10, 1.242 60'
bracketchev1221 is offline
post #12 of 15 (permalink) Old Oct 21st, 11, 1:32 PM
Matthew
Send a message via AIM to mkube396
stroke the 396 with a 4.00" or a 4.25 crank
1981 Chevy monte carlo 396 BBC .060 over 10.25:1 voodoo 60203,
3:42 Posi GTA rims
Holley 750 3310
8.61 1/8 mile on street tires
http://i190.photobucket.com/albums/z...uff/monte1.jpg
mkube396 is offline
post #13 of 15 (permalink) Old Oct 21st, 11, 2:29 PM
Send a message via Yahoo to ss3964spd
I tried to do the same thing.
I have a 961 2 bolt block from a Feb '66 assembled 1966 Impala - numbers matching to the car, making it a late '65 or early '66 block (I forget the casting date).
The block was already .060 over and the machinist advised that the cylinders didn't have enough thickness to go to 4.250.
Awww, fer cyrin out loud, it's that IMPALA guy again.
If I recall correctly my memory is excellent. My ability to access it is not.
SS 396 4sp
ss3964spd is offline
post #14 of 15 (permalink) Old Oct 21st, 11, 2:39 PM Thread Starter
alex
Thanks to all for the input, the reason im even wondering about this i cant get a 427 without breaking the bank. The blocks are even just to expensive. Its either going to be a bored 396 or a 454 block. Unless someone cuts me a deal on a vintage 427. 396 and 454 blocks are more in my price range. Wow have things gone through the roof. Thanks Guys
chevyl69 is offline
post #15 of 15 (permalink) Old Oct 21st, 11, 3:02 PM
Frank Riley
454 Block & internals w/a 396 crank will get you a 427...cheaper way to go...
70-454 LS5
Mid America Chevelle Club #293
Greater Kansas City
70-SS454 is offline
